in Maple 2023 one can do File->Open and select an .mpl file and that will automatically open in new window using code editor.  see Maple2023-CodingTools.pdf
One problem I saw right away on windows 10, is that the diagonstic window has funny character at the end of the messages. Here is screen shot
To see if you reproduce this, here is the code I used. Simply save this in foo.mpl file and then use Maple file->open to open it (must use 2023 only for this to work)
A_class :=module()
    option object;
    #my variable
    export c::integer;
    export a::integer;
end module;
That is not all. If I simply shift the code up so the starting line in the file is not empty as above, the funny characters change to something else
Yet, it is the same exact code.  Can any one confirm this problem, and how to fix it so one can read the variable name?
I think I will stick to using notepad++ for my .mpl files for now.
I have some c# function that i want to use in maple, and I doing all according to this arcticle : https://www.mapleprimes.com/posts/38019-Calling-Out-To-C-From-Maple
but i still get this:
Any ideas what i should do?
Consider the worksheet below containing a function that I came across while studying Apostol's Calculus.
At the origin, this function has a defined directional derivative in all directions. It is not, however, continuous at the origin. We can see this by consider all points on the parabola x=y^2 except for the origin. The function takes on the value 1/2 on all such points but has value 0 at the origin and is thus discontinuous there.
My question is about a 3d plot of this function.
The plot seems a bit inaccurate because the ridge at the top extends all the way to the origin.
If I hadn't done the calculations to know this, this plot would not give me this information.
Is there a way to avoid this problem? Ie, to get more accuracy at points such as the origin here?
f := (x,y) -> piecewise(x=0, 0, x <> 0, x*y^2/(x^2+y^4))
f := proc (x, y) options operator, arrow; piecewise(x = 0, 0, x <> 0, x*y^2/(x^2+y^4)) end proc
plot3d(f,-1..1,-1..1)
f(y^2,y)
piecewise(y^2 = 0, 0, y^2 <> 0, 1/2)
Download DiscontScalarField3d.mw
Not getting Mantissa or Exponentb See Bottom
    |\^/|     Maple 2022 (X86 64 LINUX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2022
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
# eqno = 10
> it := solve({
> 83.0 =  (57.9467777777778) * C_prev  + (-1.001) * C_ksteps  + (-67.1782222222222) * C_fat  + (-91.8695555555555) * C_carb  + (-24.4021555555556) * C_prot  + (-11.5003777777778) * C_fiber  + (-3.21432222222223) * C_sugar  + (-14.1697111111111) * C_saturated  + (-1.61272222222222) * C_fasted  + (1.01),
> 153.0 =  (-11.1222222222222) * C_prev  + (-1.001) * C_ksteps  + (99.9887777777778) * C_fat  + (22.2444444444444) * C_carb  + (48.3705444444444) * C_prot  + (17.2283222222222) * C_fiber  + (-5.21632222222223) * C_sugar  + (9.15358888888888) * C_saturated  + (0.389277777777778) * C_fasted  + (1.01),
> 84.0 =  (-17.1282222222222) * C_prev  + (-1.001) * C_ksteps  + (49.9387777777778) * C_fat  + (17.2394444444444) * C_carb  + (7.72994444444445) * C_prot  + (5.01612222222222) * C_fiber  + (29.8186777777778) * C_sugar  + (10.6550888888889) * C_saturated  + (1.39027777777778) * C_fasted  + (1.01),
> 78.0 =  (-8.11922222222223) * C_prev  + (0.) * C_ksteps  + (-23.1342222222222) * C_fat  + (16.2384444444445) * C_carb  + (-26.1038555555556) * C_prot  + (-12.7015777777778) * C_fiber  + (31.8206777777778) * C_sugar  + (6.05048888888888) * C_saturated  + (-1.61272222222222) * C_fasted  + (1.01),
> 87.0 =  (-8.11922222222223) * C_prev  + (3.003) * C_ksteps  + (-19.1302222222222) * C_fat  + (28.2504444444444) * C_carb  + (-16.4942555555556) * C_prot  + (-5.09397777777778) * C_fiber  + (6.79567777777777) * C_sugar  + (14.7591888888889) * C_saturated  + (-0.111222222222222) * C_fasted  + (1.01),
> 87.0 =  (37.9267777777778) * C_prev  + (-4.004) * C_ksteps  + (-48.1592222222222) * C_fat  + (-83.8615555555555) * C_carb  + (-6.08385555555555) * C_prot  + (0.611722222222222) * C_fiber  + (-58.0691222222222) * C_sugar  + (-20.0756111111111) * C_saturated  + (-1.61272222222222) * C_fasted  + (1.01),
> 133.0 =  (-17.1282222222222) * C_prev  + (3.003) * C_ksteps  + (-56.1672222222222) * C_fat  + (15.2374444444444) * C_carb  + (13.4356444444444) * C_prot  + (3.01412222222222) * C_fiber  + (13.8026777777778) * C_sugar  + (-12.2678111111111) * C_saturated  + (-0.111222222222222) * C_fasted  + (1.01),
> 78.0 =  (-11.1222222222222) * C_prev  + (1.001) * C_ksteps  + (52.9417777777778) * C_fat  + (-2.78055555555555) * C_carb  + (5.82804444444444) * C_prot  + (-0.589477777777777) * C_fiber  + (-39.5506222222222) * C_sugar  + (-0.0556111111111198) * C_saturated  + (4.39327777777778) * C_fasted  + (1.01),
> 84.0 =  (-23.1342222222222) * C_prev  + (0.) * C_ksteps  + (10.8997777777778) * C_fat  + (79.3014444444444) * C_carb  + (-2.28005555555555) * C_prot  + (4.01512222222222) * C_fiber  + (23.8126777777778) * C_sugar  + (5.95038888888888) * C_saturated  + (-1.11222222222222) * C_fasted  + (1.01) },
> [C_prev, C_ksteps, C_fat, C_carb,
>  C_prot, C_fiber, C_sugar, C_saturated,
>  C_fasted]);
                                   16                              18
it := [[C_prev = -0.7676394482 x 10  , C_ksteps = 0.1095758760 x 10  ,
                             16                             16
    C_fat = 0.7856937061 x 10  , C_carb = -0.5792833066 x 10  ,
                               17                             17
    C_prot = -0.1954662069 x 10  , C_fiber = 0.3025217874 x 10  ,
                               15                                  17
    C_sugar = 0.7496058869 x 10  , C_saturated = -0.1779505040 x 10  ,
                                 18
    C_fasted = -0.1062355291 x 10  ]]
> C_prev_V := it[1][1];
                                                          16
                   C_prev_V := C_prev = -0.7676394482 x 10
> C_prev_M := SFloatMantissa(C_prev_V);
                                                          16
                   C_prev_M := C_prev = -0.7676394482 x 10
> C_prev_E := SFloatExponent(C_prev_V);
                                                          16
                   C_prev_E := C_prev = -0.7676394482 x 10
> quit;
memory used=2.3MB, alloc=8.3MB, time=0.03
I always run with the option "create a new engine for each document". which is a very nice feature in Maple.
The problem is that, when I have say 5 worksheets open and running, and one of them them hangs, I need to kill mserver.,exe from the task manager which is running this worksheet.
most of the times I end up killing the wrong mserver.exe. I can sometimes guess by the CPU it is using. But if I have two running with high CPU it is not possible guess.
There is no ID or anything associated with the name. It will be nice if each process has in its name an ID which is also displayed in the worksheet bottom bar so one knows. This ID could be simply some random number. So the display will show  mserver-13847,exe ,   mserver-82739,exe and so on. And this name will be automtically displayed at the bottom bar of the worksheet where all time used, cpu used and memory used and so on is now displayed.  This will be a nice feature to add to Maple.
If this is not possible, how about just displaying the PID (process ID)  of the mserver.exe connected to the worksheet in the bottom bar? This will also work, as task manager/details lists a processes with the PID there, so it will make it easy to find.
Meanwhile, while waiting for Maple 2033 to hopefully implement this feature, does anyone know of a method to help find which mserver.,exe is connected to which specific worksheet?
Windows 10.
Q1: In the above, why can I only convert radians to radians. Or: Why does the menu "Chose unit" not offer arcdeg?
Q2: In the above, why is nothing happening when I enter arcdeg in the field "Enter Unit"?
Q3: How to change the displayed symbol for arcdeg to ° (in the attachment are failed attempts)?
arcdeg.mw
How to determinate cartesian equation of Surface of revolution S ( obtained by rotation of curve around line
) and how to illustrat it geometricly ?
QuestionRev.mw
Do others see this problem? I do not understand what is going on. I am seeing this problem on many integrals
int(integrand)
   #Large output displayed
   #echo the input
int(...)
    #echo the input
int(...)
    #echo the input only. Large output gone
int(...)
int(...)
   #echo the input
int(...)
int(...)
In all the above, it is the same command used.
i.e. first time (sometimes needs two times), Maple displays large out. But looking at the end of this output, the very last line, we see the same integral/command is returned.
But second time and any attempt after that, it no longer gives that large output, but returns back/echos the command on the screen only.
Attached is worksheet showing this. This is new behaviour in Maple 2023 and I am baffled by it. Do others see it? Why does it happen. I will report it if others confirm it. I just wanted to make sure first it is not just me seeing this.
Is it possible the large output is side effect and is being printed by error to the screen by internal Maple code? But why does it stop the second/third time?
int((b*g*x+a*g)^2/(A+B*ln(e*(b*x+a)/(d*x+c))),x)
(a*d-b*c)*e*d*g^2*(a^2*d^2-2*a*b*c*d+b^2*c^2)*((1/6)*(2*B^2*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)^2-6*B^2*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)^2*((a*d-b*c)*e*_z/d+b*e/d)+6*B^2*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)^2*((a*d-b*c)*e*_z/d+b*e/d)^2+4*A*B*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)-12*A*B*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)+12*A*B*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)^2-3*B^2*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)+7*B^2*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)-4*B^2*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)^2+2*A^2*b^2*e^2-6*A^2*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)+6*A^2*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2-3*A*B*b^2*e^2+7*A*B*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)-4*A*B*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2+2*B^2*b^2*e^2-4*B^2*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)+2*B^2*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2)/((-((a*d-b*c)*e*_z/d+b*e/d)*d+e*b)^3*(A+B*ln((a*d-b*c)*e*_z/d+b*e/d))^3*d^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a-3*B^2*_a+A^2-3*A*B+3*B^2)/((B*_a+A)^4*d^3*(e*b-exp(_a)*d)), _a = ln((a*d-b*c)*e*_z/d+b*e/d)))
e*(a*d-b*c)^3*d^3*((1/6)*(2*B^2*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)^2-6*B^2*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)^2*((a*d-b*c)*e*_z/d+b*e/d)+6*B^2*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)^2*((a*d-b*c)*e*_z/d+b*e/d)^2+4*A*B*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)-12*A*B*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)+12*A*B*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)^2-3*B^2*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)+7*B^2*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)-4*B^2*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)^2+2*A^2*b^2*e^2-6*A^2*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)+6*A^2*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2-3*A*B*b^2*e^2+7*A*B*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)-4*A*B*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2+2*B^2*b^2*e^2-4*B^2*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)+2*B^2*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2)/((-((a*d-b*c)*e*_z/d+b*e/d)*d+e*b)^3*(A+B*ln((a*d-b*c)*e*_z/d+b*e/d))^3*d^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a-3*B^2*_a+A^2-3*A*B+3*B^2)/((B*_a+A)^4*d^3*(e*b-exp(_a)*d)), _a = ln((a*d-b*c)*e*_z/d+b*e/d)))
-g^2*((1/6)*(2*B^2*b^2*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)^2-6*B^2*b*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+6*B^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)^2*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2+4*A*B*b^2*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)-12*A*B*b*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+12*A*B*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2-3*B^2*b^2*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)+7*B^2*b*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)-4*B^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2+2*A^2*b^2*e^2-6*A^2*b*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+6*A^2*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2-3*A*B*b^2*e^2+7*A*B*b*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)-4*A*B*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2+2*B^2*b^2*e^2-4*B^2*b*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+2*B^2*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2)*e*(a*d-b*c)^3/((e*b-e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b))^3*(A+B*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d))^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a-3*B^2*_a+A^2-3*A*B+3*B^2)/((B*_a+A)^4*d^3*(e*b-exp(_a)*d)), _a = ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d))*d^3*e*(a*d-b*c)^3)/d^3
e*(a*d-b*c)*d*(a^2*d^2-2*a*b*c*d+b^2*c^2)*((1/6)*(2*B^2*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)^2-6*B^2*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)^2*((a*d-b*c)*e*_z/d+b*e/d)+6*B^2*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)^2*((a*d-b*c)*e*_z/d+b*e/d)^2+4*A*B*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)-12*A*B*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)+12*A*B*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)^2-3*B^2*b^2*e^2*ln((a*d-b*c)*e*_z/d+b*e/d)+7*B^2*b*d*e*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)-4*B^2*d^2*ln((a*d-b*c)*e*_z/d+b*e/d)*((a*d-b*c)*e*_z/d+b*e/d)^2+2*A^2*b^2*e^2-6*A^2*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)+6*A^2*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2-3*A*B*b^2*e^2+7*A*B*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)-4*A*B*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2+2*B^2*b^2*e^2-4*B^2*b*d*e*((a*d-b*c)*e*_z/d+b*e/d)+2*B^2*d^2*((a*d-b*c)*e*_z/d+b*e/d)^2)/((-((a*d-b*c)*e*_z/d+b*e/d)*d+e*b)^3*(A+B*ln((a*d-b*c)*e*_z/d+b*e/d))^3*d^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a-3*B^2*_a+A^2-3*A*B+3*B^2)/((B*_a+A)^4*d^3*(e*b-exp(_a)*d)), _a = ln((a*d-b*c)*e*_z/d+b*e/d)))
-((1/6)*(2*B^2*b^2*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)^2-6*B^2*b*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+6*B^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)^2*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2+4*A*B*b^2*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)-12*A*B*b*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+12*A*B*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2-3*B^2*b^2*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)+7*B^2*b*e^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)-4*B^2*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d)*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2+2*A^2*b^2*e^2-6*A^2*b*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+6*A^2*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2-3*A*B*b^2*e^2+7*A*B*b*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)-4*A*B*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2+2*B^2*b^2*e^2-4*B^2*b*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)+2*B^2*e^2*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)^2)*e*(a*d-b*c)^3/((e*b-e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b))^3*(A+B*ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d))^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a-3*B^2*_a+A^2-3*A*B+3*B^2)/((B*_a+A)^4*d^3*(e*b-exp(_a)*d)), _a = ln(e*(a*d/(_z*d+c)-b*c/(_z*d+c)+b)/d))*d^3*e*(a*d-b*c)^3)/d^3
int((b*g*x+a*g)^2/(A+B*ln(e*(b*x+a)/(d*x+c))), x)
int((b*g*x+a*g)^2/(A+B*ln(e*(d*x+c)/(b*x+a))),x)
Warning, if e is meant to be the exponential e, use command/symbol completion or palettes to enter this special symbol, or use the exp function
-(a*d-b*c)*e^3*b*g^2*(a^2*d^2-2*a*b*c*d+b^2*c^2)*(-(1/6)*(2*B^2*d^2*e^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)^2+4*A*B*d^2*e^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)+2*B^2*b^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)*(-(a*d-b*c)*e*_z/b+d*e/b)^2-5*B^2*b*d*e*ln(-(a*d-b*c)*e*_z/b+d*e/b)*(-(a*d-b*c)*e*_z/b+d*e/b)+3*B^2*d^2*e^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)+2*A^2*d^2*e^2+2*A*B*b^2*(-(a*d-b*c)*e*_z/b+d*e/b)^2-5*A*B*b*d*e*(-(a*d-b*c)*e*_z/b+d*e/b)+3*A*B*d^2*e^2+2*B^2*b^2*(-(a*d-b*c)*e*_z/b+d*e/b)^2-4*B^2*b*d*e*(-(a*d-b*c)*e*_z/b+d*e/b)+2*B^2*d^2*e^2)/(d^2*e^2*(A+B*ln(-(a*d-b*c)*e*_z/b+d*e/b))^3*b*((-(a*d-b*c)*e*_z/b+d*e/b)*b-d*e)^3)-(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(-(a*d-b*c)*e*_z/b+d*e/b)))
(-a*d+b*c)^3*e^3*b*(-(1/6)*(2*B^2*d^2*e^2*ln((-a*d+b*c)*e*_z/b+d*e/b)^2+4*A*B*d^2*e^2*ln((-a*d+b*c)*e*_z/b+d*e/b)+2*B^2*b^2*ln((-a*d+b*c)*e*_z/b+d*e/b)*((-a*d+b*c)*e*_z/b+d*e/b)^2-5*B^2*b*d*e*ln((-a*d+b*c)*e*_z/b+d*e/b)*((-a*d+b*c)*e*_z/b+d*e/b)+3*B^2*d^2*e^2*ln((-a*d+b*c)*e*_z/b+d*e/b)+2*A^2*d^2*e^2+2*A*B*b^2*((-a*d+b*c)*e*_z/b+d*e/b)^2-5*A*B*b*d*e*((-a*d+b*c)*e*_z/b+d*e/b)+3*A*B*d^2*e^2+2*B^2*b^2*((-a*d+b*c)*e*_z/b+d*e/b)^2-4*B^2*b*d*e*((-a*d+b*c)*e*_z/b+d*e/b)+2*B^2*d^2*e^2)/(d^2*e^2*(A+B*ln((-a*d+b*c)*e*_z/b+d*e/b))^3*b*(((-a*d+b*c)*e*_z/b+d*e/b)*b-d*e)^3)-(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln((-a*d+b*c)*e*_z/b+d*e/b)))
-g^2*((1/6)*(2*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)^2+4*A*B*d^2*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)+2*B^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)^2-5*B^2*d*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)+3*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)+2*A^2*d^2*e^2+2*A*B*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)^2-5*A*B*d*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)+3*A*B*d^2*e^2+2*B^2*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)^2-4*B^2*d*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)+2*B^2*d^2*e^2)*e*(a*d-b*c)^3/(d^2*(A+B*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b))^3*(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)-d*e)^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b))*b*(a*d-b*c)^3*e^3)/b
-(a*d-b*c)*e^3*b*(a^2*d^2-2*a*b*c*d+b^2*c^2)*(-(1/6)*(2*B^2*d^2*e^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)^2+4*A*B*d^2*e^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)+2*B^2*b^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)*(-(a*d-b*c)*e*_z/b+d*e/b)^2-5*B^2*b*d*e*ln(-(a*d-b*c)*e*_z/b+d*e/b)*(-(a*d-b*c)*e*_z/b+d*e/b)+3*B^2*d^2*e^2*ln(-(a*d-b*c)*e*_z/b+d*e/b)+2*A^2*d^2*e^2+2*A*B*b^2*(-(a*d-b*c)*e*_z/b+d*e/b)^2-5*A*B*b*d*e*(-(a*d-b*c)*e*_z/b+d*e/b)+3*A*B*d^2*e^2+2*B^2*b^2*(-(a*d-b*c)*e*_z/b+d*e/b)^2-4*B^2*b*d*e*(-(a*d-b*c)*e*_z/b+d*e/b)+2*B^2*d^2*e^2)/(d^2*e^2*(A+B*ln(-(a*d-b*c)*e*_z/b+d*e/b))^3*b*((-(a*d-b*c)*e*_z/b+d*e/b)*b-d*e)^3)-(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(-(a*d-b*c)*e*_z/b+d*e/b)))
-((1/6)*(2*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)^2+4*A*B*d^2*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)+2*B^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)^2-5*B^2*d*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)+3*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b)+2*A^2*d^2*e^2+2*A*B*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)^2-5*A*B*d*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)+3*A*B*d^2*e^2+2*B^2*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)^2-4*B^2*d*e^2*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)+2*B^2*d^2*e^2)*e*(a*d-b*c)^3/(d^2*(A+B*ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b))^3*(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)-d*e)^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(e*(-a*d/(_z*b+a)+b*c/(_z*b+a)+d)/b))*b*(a*d-b*c)^3*e^3)/b
int((b*g*x+a*g)^2/(A+B*ln(e*(d*x+c)/(b*x+a))), x)
-e^3*(a*d-b*c)*b*g^2*(a^2*d^2-2*a*b*c*d+b^2*c^2)*(-(1/6)*(2*B^2*d^2*e^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)^2+4*A*B*d^2*e^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)+2*B^2*b^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)*(-e*(a*d-b*c)*_z/b+d*e/b)^2-5*B^2*b*d*e*ln(-e*(a*d-b*c)*_z/b+d*e/b)*(-e*(a*d-b*c)*_z/b+d*e/b)+3*B^2*d^2*e^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)+2*A^2*d^2*e^2+2*A*B*b^2*(-e*(a*d-b*c)*_z/b+d*e/b)^2-5*A*B*b*d*e*(-e*(a*d-b*c)*_z/b+d*e/b)+3*A*B*d^2*e^2+2*B^2*b^2*(-e*(a*d-b*c)*_z/b+d*e/b)^2-4*B^2*b*d*e*(-e*(a*d-b*c)*_z/b+d*e/b)+2*B^2*d^2*e^2)/(d^2*e^2*(A+B*ln(-e*(a*d-b*c)*_z/b+d*e/b))^3*b*((-e*(a*d-b*c)*_z/b+d*e/b)*b-d*e)^3)-(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(-e*(a*d-b*c)*_z/b+d*e/b)))
e^3*(-a*d+b*c)^3*b*(-(1/6)*(2*B^2*d^2*e^2*ln(e*(-a*d+b*c)*_z/b+d*e/b)^2+4*A*B*d^2*e^2*ln(e*(-a*d+b*c)*_z/b+d*e/b)+2*B^2*b^2*ln(e*(-a*d+b*c)*_z/b+d*e/b)*(e*(-a*d+b*c)*_z/b+d*e/b)^2-5*B^2*b*d*e*ln(e*(-a*d+b*c)*_z/b+d*e/b)*(e*(-a*d+b*c)*_z/b+d*e/b)+3*B^2*d^2*e^2*ln(e*(-a*d+b*c)*_z/b+d*e/b)+2*A^2*d^2*e^2+2*A*B*b^2*(e*(-a*d+b*c)*_z/b+d*e/b)^2-5*A*B*b*d*e*(e*(-a*d+b*c)*_z/b+d*e/b)+3*A*B*d^2*e^2+2*B^2*b^2*(e*(-a*d+b*c)*_z/b+d*e/b)^2-4*B^2*b*d*e*(e*(-a*d+b*c)*_z/b+d*e/b)+2*B^2*d^2*e^2)/(d^2*e^2*(A+B*ln(e*(-a*d+b*c)*_z/b+d*e/b))^3*b*((e*(-a*d+b*c)*_z/b+d*e/b)*b-d*e)^3)-(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(e*(-a*d+b*c)*_z/b+d*e/b)))
-g^2*((1/6)*(2*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)^2+4*A*B*d^2*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)+2*B^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)^2-5*B^2*d*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)+3*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)+2*A^2*d^2*e^2+2*A*B*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)^2-5*A*B*d*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)+3*A*B*d^2*e^2+2*B^2*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)^2-4*B^2*d*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)+2*B^2*d^2*e^2)*e*(a*d-b*c)^3/(d^2*(A+B*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b))^3*(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)-d*e)^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b))*b*(a*d-b*c)^3*e^3)/b
-e^3*(a*d-b*c)*b*(a^2*d^2-2*a*b*c*d+b^2*c^2)*(-(1/6)*(2*B^2*d^2*e^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)^2+4*A*B*d^2*e^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)+2*B^2*b^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)*(-e*(a*d-b*c)*_z/b+d*e/b)^2-5*B^2*b*d*e*ln(-e*(a*d-b*c)*_z/b+d*e/b)*(-e*(a*d-b*c)*_z/b+d*e/b)+3*B^2*d^2*e^2*ln(-e*(a*d-b*c)*_z/b+d*e/b)+2*A^2*d^2*e^2+2*A*B*b^2*(-e*(a*d-b*c)*_z/b+d*e/b)^2-5*A*B*b*d*e*(-e*(a*d-b*c)*_z/b+d*e/b)+3*A*B*d^2*e^2+2*B^2*b^2*(-e*(a*d-b*c)*_z/b+d*e/b)^2-4*B^2*b*d*e*(-e*(a*d-b*c)*_z/b+d*e/b)+2*B^2*d^2*e^2)/(d^2*e^2*(A+B*ln(-e*(a*d-b*c)*_z/b+d*e/b))^3*b*((-e*(a*d-b*c)*_z/b+d*e/b)*b-d*e)^3)-(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(-e*(a*d-b*c)*_z/b+d*e/b)))
-((1/6)*(2*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)^2+4*A*B*d^2*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)+2*B^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)^2-5*B^2*d*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)+3*B^2*d^2*e^2*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b)+2*A^2*d^2*e^2+2*A*B*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)^2-5*A*B*d*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)+3*A*B*d^2*e^2+2*B^2*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)^2-4*B^2*d*e^2*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)+2*B^2*d^2*e^2)*e*(a*d-b*c)^3/(d^2*(A+B*ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b))^3*(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)-d*e)^3)+(1/3)*intat(B*(B^2*_a^2+2*A*B*_a+3*B^2*_a+A^2+3*A*B+3*B^2)/(d^2*e^2*(B*_a+A)^4*b*(exp(_a)*b-d*e)), _a = ln(e*(-a*d/(_z*b+a)+c*b/(_z*b+a)+d)/b))*b*(a*d-b*c)^3*e^3)/b
Download int_stops_working_march_11_2023.mw
Update
Do you want to see something more bizzar? Try this command on same integral
res:=int((b*g*x+a*g)^2/(A+B*ln(e*(b*x+a)/(d*x+c))),x,method=_RETURNVERBOSE)
It prints to the screen results with ~ all over. But this seems to be internal leaked output and not part of the actual output returned.
By issuing the command as follows instead
res:=int((b*g*x+a*g)^2/(A+B*ln(e*(b*x+a)/(d*x+c))),x,method=_RETURNVERBOSE):
notice the at the end!  I still see the same output as above printed displayed.
This tells me this is a leaked printout from an internal integration function.
Could others confirm this?
How would I produce output from ShowSolution in Latex form?
For example, if I run the following command.
$ maple2022/bin/maple -q problem.mpl
where problem.mpl is the following:
with(Student[Calculus1]):
ShowSolution(Diff(ln(x),x));
I get the following output.
Differentiation Steps
    Diff(ln(x),x)
▫    1. Apply the natural logarithm rule
        ◦ Recall the definition of the natural logarithm rule
        Diff(ln(x),x) = x^(-1)
    This gives:
    x^(-1)
I want the solver to show the steps in Latex form. How can I achieve this?
First issue I see in Maple 2023 integrate
Example 1
int( (e*x+d)^(3/2)*(c*x^2+a)^(3/2),x)
Example 2
int((1+x)^(3/2)*(x^2-x+1)^(3/2),x);
Example 3
int((c*x^4+b*x^2)^(3/2)/x^(3/2),x)
Worksheet below for 2023 and also for 2022.2 showing this did not have this problem in 2022.2. Internally for me, this cause other problem when post-processing this, that is why I found it. Any one knows what caused it?  Maple 2022.2 result is much longer, but it does have this "undefined" issue in the result.
(e*x+d)^(1/2)*(c*x^2+a)^(1/2)*undefined*x*(3*c*e*x^3+4*c*d*x^2+6*a*e*x+12*a*d)/(c*e*x^3+c*d*x^2+a*e*x+a*d)^(1/2)
(1+x)^(1/2)*(x^2-x+1)^(1/2)*undefined*x*(x^3+4)/(x^3+1)^(1/2)
undefined*(c*x^2+2*b)*(c*x^4+b*x^2)^(3/2)/(x^(1/2)*(c*x^2+b)*(x*(c*x^2+b))^(1/2))
Download bug_3_maple_2023_int_march_10_2023.mw
(2/1155)*(e*x+d)^(1/2)*(c*x^2+a)^(1/2)*(372*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c*a^3*d*e^6+245*x^6*c^4*d*e^6+300*x^5*a*c^3*e^7+145*x^5*c^4*d^2*e^5-x^4*c^4*d^3*e^4+255*x^3*a^2*c^2*e^7+2*x^3*c^4*d^4*e^3+8*x^2*c^4*d^5*e^2+60*x*a^3*c*e^7+360*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c^2*a^2*d^3*e^4-12*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c^3*a*d^5*e^2-16*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*(-c*a)^(1/2)*c^3*d^6*e-432*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticE((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c*a^3*d*e^6-336*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticE((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c^2*a^2*d^3*e^4+112*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticE((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c^3*a*d^5*e^2+766*x^4*a*c^3*d*e^6+16*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticE((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*c^4*d^7+60*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*(-c*a)^(1/2)*a^3*e^7+518*x^3*a*c^3*d^2*e^5+581*x^2*a^2*c^2*d*e^6+46*x^2*a*c^3*d^3*e^4+373*x*a^2*c^2*d^2*e^5+2*x*a*c^3*d^4*e^3+60*a^3*c*d*e^6+47*a^2*c^2*d^3*e^4+8*a*c^3*d^5*e^2+105*x^7*c^4*e^7-24*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*(-c*a)^(1/2)*a^2*c*d^2*e^5-100*(-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2)*((-x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e+d*c))^(1/2)*((x*c+(-c*a)^(1/2))*e/((-c*a)^(1/2)*e-d*c))^(1/2)*EllipticF((-(e*x+d)*c/((-c*a)^(1/2)*e-d*c))^(1/2), (-((-c*a)^(1/2)*e-d*c)/((-c*a)^(1/2)*e+d*c))^(1/2))*(-c*a)^(1/2)*a*c^2*d^4*e^3)/(c^2*e^5*(c*e*x^3+c*d*x^2+a*e*x+a*d))
-(1/55)*(1+x)^(1/2)*(x^2-x+1)^(1/2)*(-10*x^7+(27*I)*3^(1/2)*(-2*(1+x)/(-3+I*3^(1/2)))^(1/2)*((I*3^(1/2)-2*x+1)/(I*3^(1/2)+3))^(1/2)*((I*3^(1/2)+2*x-1)/(-3+I*3^(1/2)))^(1/2)*EllipticF((-2*(1+x)/(-3+I*3^(1/2)))^(1/2), (-(-3+I*3^(1/2))/(I*3^(1/2)+3))^(1/2))-81*(-2*(1+x)/(-3+I*3^(1/2)))^(1/2)*((I*3^(1/2)-2*x+1)/(I*3^(1/2)+3))^(1/2)*((I*3^(1/2)+2*x-1)/(-3+I*3^(1/2)))^(1/2)*EllipticF((-2*(1+x)/(-3+I*3^(1/2)))^(1/2), (-(-3+I*3^(1/2))/(I*3^(1/2)+3))^(1/2))-38*x^4-28*x)/(x^3+1)
Download maple_2022_int_march_10_2023.mw
When will the PDF Maple User Manual be released for Maple 2023. Also I hope the Programming guide is updated too as it is still at 2020.
I know that this is not really a question regarding core Maple package, but I am running into problems during the installation process.
After having upgraded Maple networktools as mentioned, I am unable to run the activation program due to an error.
"Java Virtual Machine Launcher: Error: Could not create the Java Virtual Machine."
I've never had that problem before in previous versions. There was no Java installed on the (virtual) server, so I installed the latest OpenJDK to check if that solved the problem.
Unfortunately it didn't.
Any hints would be appreciated.
Windows Server 2012R2
The command for doing syntactical exact-match substitutions is subs, however, subs applies transformation rules throughout an expression only once. The documentation of eval claims that the (recursive) evaluation is repeated until either the result does not change, the documentation of applyrule claims that applyrule … applies the rules until no rule can be applied any more, and the documentation of MmaTranslator[Mma][ReplaceRepeated] claims that the single ReplaceRepeated command performs replacements until expression no longer changes.
So, if I comprehend correctly,
x := [[[[]]]]: # Remove empty lists from x repeatedly.
(*⒈*) eval['recurse'](x, [[] = 'NULL']);
(*⒉*) applyrule([[] = 'NULL'], x);
(*⒊*) MmaTranslator:-Mma:-ReplaceRepeated(x, [[] = NULL])
should all return NULL, but in fact,
Error, (in PatternMatching:-AlgStruct:-TableLookup) invalid input: unknown uses a 1st argument, x, which is missing
MmaTranslator:-Mma:-ReplaceRepeated(x, [[] = NULL]);
In other words, none of these replacements is feasible.
Have I missed something? (It seems to me that an explicit procedural do...until loop can be actually avoidable here!)
My main question is: How to change the font used in worksheet by Maple for 1D input from Courier to another font say times new roman? Is there a setting for this so it applies all the time?
ps. I found Can-I-Change-the-Default-Fonts-or-Style-for-Maple-Worksheets-and-Documents?language=en_US  (very hard to follow and confusing, but it seems that is only way to fix this problem now is to change the default font).
I noticed strange font problem using Maple 2023 on windows 10. This problem does not show on Maple 2022.2 (at least I do not think I've seen it or noticed it before).
Variables with _ between the names, will have the underscore not display sometimes as I move the cursor around (movie at end).
When scrolling back up, the underscores no longer become visible.
But as I move the cursor over the variable name which containes the underscore, they will now show up.
I am sure this is a font issue. The zoom is set at 100%. I made no changes at all other than making the input 1D math as I normally do and set the default to worksheet. Some of my setting are below.
This could be a DPI issue settings of some sort. My monitor is standard monitor (not a 4K one) and again, I have not changed any settings on my PC after I installed Maple 2023 and did not change any hardware.
Here is some system information also
Here is the movie showing the problem
As I play more with it, I notice a common theme. This happens when I hit the UP ARROW to go to the line above. Then suddenly the underscroes no longer visible. Once I hit the LEFT arrow (now I am at the above line), they show up again.
Here is another movie which more clearly shows this.
This makes it very hard to work with the code in the worksheet. But I am sure this can be fixed as it looks like just a font configuration issue with Maple on windows. But I do not know what it is and how to fix it.
I found something new. When setting the ZOOM at 125% instead of 100% as above, I notice the underscores do not completely disappear but become THINNER but one can still see them. This affects only the underscores. When the ZOOM at 150%, they do not change at all.  Here is a movie. first part at 125%. Notice how they become little thinner when doing the same thing as above. But at 150% they remain visible because they do not change thinkness. When going back to 100% zoom, they  no longer show.
So the problem is that they are there all the time, but depending on the ZOOM level, they beome thinner and thinner until they become invisible to the eye.
I found some related issue on windows 10 with some application where this problem shows up.
some-characters-missing-or-cut-off-when-displayed-on-screen
 "When you view your document in Microsoft Word, some characters may be missing, or the top (or bottom) of some characters may be cut off.
This problem may affect the following types of characters:
Underscore"
The above is about WORD, but it could as well apply to Maple?
I also found  underscore not rendering with courier
"Underscore characters are not rendered in new Google Docs in the Courier
New 11pt or 12pt fonts."
My question is: How to change the font used in worksheet by Maple? Now it is using Courier. May be if I change the font, this problem will go away?
Update: Found a workaround!  It is the font used!  I changed from Courier to Times New Roman and now the underscore do not change thinkness!  I just need a way to make this permenant for all 1D Maple input.   Here is a new movie showing it is fixed. You can see the underscores remain visible, all at 100% ZOOM level. Once I change to Courier, the problem show up again.
I am not sure if this is a Maple issue or windows.
with(plottools)
with(plots)
with(CurveFitting)
Digits := 10
"f(t):=7.0*(e)^((-(t-13180)^(2))/(2000000))+4.7*(e)^((-(t-16000)^(2))/(3200000)):"
p1 := plot(f(t), t = 0 .. 20000, color = green); plots[display]({p1})
D1 := 15
epsilon := 200000
L := 6500
n := 200
t := 1000
1000
lambda := simplify(evalf(n*Pi*sqrt((1/2)*D1+sqrt((1/4)*D1^2+epsilon*(n*Pi/L)^2))/L))
.6928578233
b := 2*(int(f(t)*sin(m*Pi*x/L), x = 0 .. L))/L
-0.6366197724e-1*(0.1409730543e-28*cos(3.141592654*m)-0.1409730543e-28)/m
C(x, t) = sum(b*exp^(-lambda^2*t)*sin(m*Pi*x/L), m = 1 .. 2)
C(x, 1000) = 0.1794924675e-29*sin(0.4833219466e-3*x)/exp^(4800519633/10000000)
uu1000 := [seq(evalf(C(L-i, t)), i = 0 .. 6500, 100)]
[C(6500, 1000), C(6400, 1000), C(6300, 1000), C(6200, 1000), C(6100, 1000), C(6000, 1000), C(5900, 1000), C(5800, 1000), C(5700, 1000), C(5600, 1000), C(5500, 1000), C(5400, 1000), C(5300, 1000), C(5200, 1000), C(5100, 1000), C(5000, 1000), C(4900, 1000), C(4800, 1000), C(4700, 1000), C(4600, 1000), C(4500, 1000), C(4400, 1000), C(4300, 1000), C(4200, 1000), C(4100, 1000), C(4000, 1000), C(3900, 1000), C(3800, 1000), C(3700, 1000), C(3600, 1000), C(3500, 1000), C(3400, 1000), C(3300, 1000), C(3200, 1000), C(3100, 1000), C(3000, 1000), C(2900, 1000), C(2800, 1000), C(2700, 1000), C(2600, 1000), C(2500, 1000), C(2400, 1000), C(2300, 1000), C(2200, 1000), C(2100, 1000), C(2000, 1000), C(1900, 1000), C(1800, 1000), C(1700, 1000), C(1600, 1000), C(1500, 1000), C(1400, 1000), C(1300, 1000), C(1200, 1000), C(1100, 1000), C(1000, 1000), C(900, 1000), C(800, 1000), C(700, 1000), C(600, 1000), C(500, 1000), C(400, 1000), C(300, 1000), C(200, 1000), C(100, 1000), C(0, 1000)]
xx := [seq(k, k = 0 .. 6500, 100)]
p2 := plot(xx, uu1000, color = cyan)
Error, (in plot) two lists or Vectors of numerical values expected
plots[display]({p2})
Error, (in plots:-display) expecting plot structures but received: {p2}
Download easy_way.mw
First 226 227 228 229 230 231 232 Last Page 228 of 2431
