How to show the y-axis numbers in the second plot ?   y is in [0,3].
I try the following but it shows a negative axis.
display(P, L, axis = [tickmarks = [5, subticks = 3], thickness = 2]);  this is not correct
The file is attached.
Download Curves.mw
I do not understand why the following is not working. I have a package which has a module inside it. The module is exported by the package.
Inside that module, there is a proc, which is also exported by the module.
So why can't one call the proc from outside the package? What Am I doing wrong? and how to correct it? I'd like to be able to call the proc directly.
A:=module()
  option package;
  export B;
  B := module()
      export foo;
      foo:=proc()
           print("in foo");
  end module;
end module;
Now when typing (A::B):-foo() Maple is not happy and says Error, module does not export `foo`
I tried different syntax from the above, but can't get it to work. For example A::B:-foo() gives Error, `B` does not evaluate to a module
Maple 2019.1
P; Q; lma; [3 -42] [-, ---] [2 25 ] [22649 -2304] [-----, -----] [5523 1841 ] 1.627112258 with(geometry); point(Pp, P[1], P[2]); point(Qp, Q[1], Q[2]); ellipse(p, ['foci' = [Pp, Qp], 'MajorAxis' = lma]); Error, (in geometry:-ellipse) the given polynomial/equation is not an algebraic representation of a ellipse; I can't understand this error
Hi I’m a student, running Maple on a student license, and I have an issue with the way the Maple 2019 setup is.
I'm sorry if my answer is a bit hard to understand, I don't really know how to explain it.
My Maple 2018 expired and I was forced to upgrade to Maple 2019, however for me there is a huge difference in how the setup is in therms of “math” and “text” mode.
Before, I was able to easily switch between “text” and “math” mode in a paragraph (the red “>”) in my worksheet, by using “cmd+R” and “cmd+T”. So I would have paragraphs for text, where i could switch between “math” and “text” for writing, and then I would have paragraphs only for math for when I would calculate things. (I’ve tried to screenshot how it would typically look)
Mt problem with Maple 2019, is that when I switch a paragraph into text and start writing and want to switch to “math” by using “cmd+R”, Maple executes the formula whenever I press “enter”, and give me an output I don’t want.
How do I change the settings to get back to the way they were on Maple 2018 and the years before this?
(I know I can put a ":" after the "math" part in my text, but i don't wan't to do it every time)
When making a proc that accepts positional and keyword based arguments, Maple allows the caller to put the keyword arguments before or after the positional arguments, or in between.
Is there a way to force the keyword arguments (if they are used) to only be placed after the (required) positional arguments during the call?
An example will make it more clear. Given this proc
foo := proc(a::integer, b::integer, {c::integer:= 1, d::integer:= 1},$)
    print("a=",a," b=",b," c=",c," d=",d);
It can be called as any one of these cases
foo(1,2);                                #case 1
foo(1, 2,'c' = 1, 'd' = 2);              #case 2
foo('c' = 1, 1, 'd' = 2, 2);             #case 3
foo('c' = 1, 1, 2);                      #case 4
foo(1, 'c'=1, 2);                        #case 5
#more combinations possible
Is it possible to change how proc is defined, so that Maple will accept case1, and case 2 only in the above when the call is made and give an error otherwise?
i.e. only allow keyword arguments after all positional arguments.  I read https://www.maplesoft.com/support/help/Maple/view.aspx?path=argument_processing  and it says
After all arguments matching keyword parameters have been processed, matching of required positional and optional or expected ordered parameters is carried out
So from above, it looks like what I am asking for is not really possible. But I thought to ask, in case there is some way.
I find ability to put keyword arguments in the call anywhere and in-between required positional arguments confusing that is all.
Maple 2019.1
I am trying to expand a multivariable (more specifically 4 variables) function in powers of one of its variables when it goes to infinity.
However, the result I get is always zero, even if I input (or not) values for some of the other variables.
Can anybody help?
series_expansion.mw
P.s.: I want to do the same for the other two functions I defined in the worksheet as well.
Is there a command or method in Maple to list all initially protected names?
This page https://www.maplesoft.com/support/help/Maple/view.aspx?path=UndocumentedNames list undocumented protected names, and this page https://www.maplesoft.com/support/help/Maple/view.aspx?path=initialconstants  lists initially known names, which I assume are all protected.
But what about a list of all protected names? sin,cos, eval, uneval, etc.. any name that can't be assigned to. In my search so far, I could not find how to find these names. There are 100's of such names. Can one get them all in a list to look at?
Using Maple 2019.1
I want to solve the following system using PDE Solve command but finding an error. Please help me in this regard. Thanks!
restart; d1 := 1; d2 := 1; AA := 0.2e-2; BB := 0.79e-1; L := 1;
with(PDEtools, casesplit, declare);
PDE1 := diff(u(x, t), t) = d1*(diff(u(x, t), x, x))-u(x, t)*v(x, t)^2+AA*(1-u(x, t)); PDE2 := diff(v(x, t), t) = d1*(diff(v(x, t), x, x))+u(x, t)*v(x, t)^2-BB*v(x, t);
                      /  2         \
         d            | d          |                  2
PDE1 := --- u(x, t) = |---- u(x, t)| - u(x, t) v(x, t)  + 0.002
         dt           |   2        |
                      \ dx         /
   - 0.002 u(x, t)
                          /  2         \
             d            | d          |                  2
    PDE2 := --- v(x, t) = |---- v(x, t)| + u(x, t) v(x, t)
             dt           |   2        |
                          \ dx         /
       - 0.079 v(x, t)
IBC1 := {u(0, t) = 1, u(1, t) = 1, u(x, 0) = 1-(1/2)*sin(Pi*(x-L)/(2*L))^100}; IBC2 := {v(0, t) = 0, v(1, t) = 0, v(x, 0) = (1/4)*sin(Pi*(x-L)/(2*L))^100}; dys1 := {IBC1, IBC2, PDE1, PDE2};
         /              /  2         \
         | d            | d          |                  2
dys1 := < --- u(x, t) = |---- u(x, t)| - u(x, t) v(x, t)  + 0.002
         | dt           |   2        |
         \              \ dx         /
   - 0.002 u(x, t),
                /  2         \
   d            | d          |                  2
  --- v(x, t) = |---- v(x, t)| + u(x, t) v(x, t)  - 0.079 v(x, t),
   dt           |   2        |
                \ dx         /
   /                                                           100
   |                                        1    /1           \
  < u(0, t) = 1, u(1, t) = 1, u(x, 0) = 1 - - sin|- Pi (x - 1)|
   |                                        2    \2           /
   /                                                       100\
   |                                    1    /1           \   |
  < v(0, t) = 0, v(1, t) = 0, v(x, 0) = - sin|- Pi (x - 1)|    >
   |                                    4    \2           /   |
pds := pdsolve(dys1, numeric, time = t, range = 0 .. 1);
Error, (in pdsolve) invalid input: `pdsolve/numeric` expects its 2nd argument, IBCs, to be of type {list, set}, but received time = t
p1 := pds:-plot(t = 0, numpoints = 50);
p2 := pds:-plot(t = 1/8, numpoints = 50, color = blue);
p3 := pds:-plot(t = 1/4, numpoints = 50, color = green);
plots[display]({p1, p2, p3});
Error, `pds` does not evaluate to a module
Error, (in plots:-display) expecting plot structures but received: {p1, p2, p3}
Hi, Is there a way in which i can solve the following optimal control problem numerically with Maple ??
where P(t)=N(t)+S(t)+A(t) and N(0)=0.4897, S(0)=0.4018, A(0)=0.1085.
μ=0.000833, d=0.000666, ε1=0.0020, ε2=0.000634, β1=0.002453, β2=0.25*0.02, γ1=0.0048, γ2=0.25*0.02+0.00013, k1=1, k2=0.001, k3=0.99.
 where
p1,p2,p3 are transversality conditions
p1(60)=0
p2(60)=0
p3(60)=0
Answers and advice are very appreciated.
Thank you all for reading.
Benz.
Hi MaplePrimes team,
If I assume a plot-based function or procedure C(s,t) and P1(t) are hidden in a package somewhere I don’t care about the type of geometry (spacecurve or plot3d). Now, I just want to animate P1(t) following the variable t. How do I do?
Example 1: Curve Animation in variable t
1. Equation
C := (s,t)-> Vector([cos(s), sin(s), t*s/2]):     #Helix shape as example
2. Plot
P1 := t-> display(spacecurve(C(s,t), s = 0..3*2*Pi, linestyle = solid)):
Example 2: Surface Animation in variable t
1. Equation
S := (x,y,t)-> Vector([x, y, t/(1 + x^2 + y^2)]):
2. Plot
P2 := t-> display(plot3d(S(x,y,t), x = -2..2, y = -2..2)):
If I assume the function or procedure S(x,y,t) and P2(t) are hidden in a package somewhere I don’t care. Now, I just want to animate P2(t) following the variable t. How do I do?
Example 3: Mixing Curve and Surface Animation in variable t
The ideal/”dream” basic syntax would be:
animate(display, [P1(t), P2(t)], t = t1..t2)
But it does not work.
Best.
Guy.
What is the problem in the following code to solve given PDE?
pde_question.mw
hi everybody:
I have two Maple files that file 1.mw file is a package and 2.mw file is based on the 1.mw file when running the 2.mw file I see the error and don't know how to solve it, I attach these files, thank you for helping me.
1.mw
2.mw
No doubt that someone will provide a smarter solution:
# the main idea
f := exp(a-b);
subs(B=-b, expand(subs(b=-B, f)));
exp(a-b)
exp(a)*exp(-b)
# ad hoc application
f := 2*gamma(t, r)-2*alpha(t, r)-2*beta(t, r);
c := op~(1, [op(f)]);
C := [seq(u[i], i=1..numelems(c))];
subs(C=~c, expand(subs(c=~C, exp(f))))
[2, -2, -2]
[u[1], u[2], u[3]]
exp(2*gamma(t, r))*exp(-2*alpha(t, r))*exp(-2*beta(t, r))
Download exp.mw
Could someone confirm if this is a problem in this sample application?
In 2019, in the folder
    C:\Program Files\Maple 2019\samples\ProgrammingGuide\RandomnessTests
There is sample application. Opening the main module file RandomnessTests.mpl  and scrolling down a little bit to the include statements show
$include "WaldWolfowitz.mm"
$include "BitFrequency.mm"
$include "SequenceFrequency.mm"
$include "Compressibility.mm"
$include "BinaryRank.mm"
$include "Entropy.mm"
$include "Data.mm"
$include "Visualization.mm"
However, in the same folder, there is no Data.mm file. There is only Data.mpl file.
So how could this sample application work?
This sample app have more problems. The file Visualization.mm  say
Data := module()
option package;
And the file Data.mpl has
Data := module()
This is all so confusing. Seems someone made some typos and not tested this app? Why put a sample application which makes learning packages in Maple more confusing?
ps. I did not yet try to figure how to locad it and run it myself, I was just browsing it.
I have the following expression
I would like to know if is it possible avoid negative exponent goes to denominator when I use expand().
First 665 666 667 668 669 670 671 Last Page 667 of 2433
