I never really understood Intat. Help says
"The intat command expresses an integral evaluated at a point; it is analogous to using the D command to express a derivative evaluated at a point."
But slope at a point is clear what it is and one can visualize it.
I do not understand what integral at single point means.
If one thinks of integration as area under the curve of the function, so what does area at single point mean? Should not integration (definite) always have lower and upper limits?
But my main question is not the above. I am sure there is a valid reason for Intat, otherwise it will not be in Maple.
But my quesiton is, in the context of solution to ode, can one replace result given using Intat by Int such that the lower limit starts from zero, and using same upper limit?
ie change Intat(...., a_ = something)  by Int( ... , a_ = 0 ... something) without changing the semantics or the correctness of the solution?
Because in  Intat, the lower limit is empty, and this always bothered me. At school the teacher says definite integration should have both lower and upper limits.
I tried it few places, and odetest verifies the solution of ode when using Intat or when using Int with lower limit zero:
ode:=diff(y(x), x) = B + C*f(a*x + b*y(x));
diff(y(x), x) = B+C*f(a*x+b*y(x))
sol_1:=Intat(1/(C*f(_a*b)*b+b*B+a),_a = (a*x+b*y(x))/b)*b-x+_C1 = 0;
sol_2:=Int(1/(C*f(_a*b)*b+b*B+a),_a = 0..(a*x+b*y(x))/b)*b-x+_C1 = 0;
Intat(1/(C*f(_a*b)*b+b*B+a), _a = (a*x+b*y(x))/b)*b-x+_C1 = 0
(Int(1/(C*f(_a*b)*b+b*B+a), _a = 0 .. (a*x+b*y(x))/b))*b-x+_C1 = 0
odetest(sol_1,ode);
odetest(sol_2,ode);
Download intat_vs_int.mw
Is there a case you know, where solution of ode which has Intat, when replaced by Int with lower limit 0, will no longer verifies the ode?  I am not able to find one so far. But may be there is.
Update
fyi, I found case where it makes difference. Not for odetest, but when using value. When using Int(...,tau=0..upper) vs   Intat(....,tau=upper)
value was able to find the value when using Intat, but not when using Int (for this example).
So I think I will just stick to Intat even though both verified the ode as valid solution as it is better to be able to find value for integral if possible. I knew there must be good reason why Intat was invented.
ode:=diff(y(x),x)= sin(x-y(x));
diff(y(x), x) = sin(x-y(x))
sol_1:=Int(1/(1 - sin(tau)), tau = 0..x - y(x)) = x + _C1;
sol_2:=Intat(1/(1 - sin(tau)), tau = x - y(x)) = x + _C1;
Int(1/(1-sin(tau)), tau = 0 .. x-y(x)) = x+_C1
Intat(1/(1-sin(tau)), tau = x-y(x)) = x+_C1
odetest(sol_1,ode);
odetest(sol_2,ode);
value(sol_1);
int(1/(1-sin(tau)), tau = 0 .. x-y(x)) = x+c__1
value(sol_2);
-2/(tan((1/2)*x-(1/2)*y(x))-1) = x+c__1
Download int_vs_intat_v2.mw
@Rouben Rostamian
Dear Sir Professor Rostamian my name is Viorel Popescu from the Polytechnic University of Bucharest if you remember in the summer of 2019 you helped me to solve the equation: rH''(r)+H'(r)+(rk^2-r^2*b^2/R^2)H(r)=0 where k, b, and R are real constants positive number, with condition H(R)=0 and H'(1/R)=R. I appreciate it very much, please I'm in a similarly embarrassing situation to beg you for an answer. I want to find the equation of audion and complete the experiment http://www.michaelvio.byethost8.com/Audion.pdf
My account in Maple Primes is the same michaelvio (35) as the email michaelvio@yahoo.com and also @gmail.com it's an experiment that I want to make for my PhD. Practically I suppose that the energy can be approx. as a series of power of frequency t from I selected severaral terms Ea := 0.00762014687*t + a*t^2 + b*t^3 + c*t^4 + d*t^5 and I guess that satisfies an equation as in the document. The case of photons is beyond my possibility, but a little help from a distinguished Professor as you should cheer me up Audion1.mw
Audion.docx
Please help!
I need to automatically solve this system, that is, both equations simultaneously for different intervals of T that I define. For example, from T=0.1 to 4, then from 4.5 to 5 and from 7 to 8 with distinct subdivisions between them, the first varying by 0.1, the second by 0.05 and the third by 0.25. Furthermore, the index that accompanies m and G is only illustrative. Would anyone know how to help me?
Thank you for your help!
I have expression which can have many different functions  in it. Assume the expression is `+` type.
I do not know before what these function names are.
Is there a way to make Maple collect on these functions automatically? Simplify does not do it. So if there is something like b*g(x)+g(x) in the expression, to simplify this to (1+b)*g(x) automatically?
I noticed if expression is   just b*g(x)+g(x) then simplify does give (1+b)*g(x) but once I add a new term, like 3+b*g(x)+g(x) then it no longer does it! which for me is very strange. I was expecting to get 3+(1+b)*g(x)
Here is an example
T:=g(x)+b*g(x);
simplify(T);
g(x)+b*g(x)
g(x)*(b+1)
T:=3+g(x)+b*g(x);
simplify(T);
3+g(x)+b*g(x)
3+g(x)+b*g(x)
T:=3+g(x)+b*g(x)+f(x);
simplify(T);
3+g(x)+b*g(x)+f(x)
3+g(x)+b*g(x)+f(x)
Download simplification_oct_9_2024.mw
What do I need to do to get this output using another software
Ofcourse, I could go and add code to find the names of each function and then use collect. But it seems to me simplify should have done this automatically as the above shows. So I am wondering if there is an option I've overlooked which will do this more easily.
Maple 2024.1
In the rectangular Cartesian coordinate system, three straight lines gA, gB, gC are given, which are not all parallel to each other. Another straight line g and the points Oa, Ob, Oc on it are given. A triangle ABC is to be constructed, one of whose vertices lies on gA, gB or gC and the triangle sides a, b and c (or their extensions) each run through Oa, Ob or Oc.
We are looking for the coordinates of the vertices A, B, C.
In a purely constructive solution, the calculation can be omitted.
Hi everyone, I just try a simple equivalent implicitplot3d code regarding Maple and matlab to see difference. First for Maple, I don't set grid, just input one random complicated function and displays "Warning, solutions may have been lost", while matlab doesn't, but it's figure cannot compare with maple's in terms of detail or beauty (just focused on this case). I wanna know why. Hope for your reply!
The Maple code is as below
with(plots)
implicitplot3d(x^(2*z)+y^(-2*y^(-z))+exp(-.1*z^2) = 1)
Download implicitplot3d_solution_lost_try.mw
The orange font is equivalent matlab code and figure is attached.
% Define the function for implicit plotting
f = @(x, y, z) x.^(2*z) + y.^(-2*y.^(-z)) + exp(-0.1*z.^2) - 1;
% Use fimplicit3 for 3D implicit plotting
fimplicit3(f, [-2 2 -2 2 -2 2]);
% Set labels and title
xlabel('x');
ylabel('y');
zlabel('z');
title('Implicit 3D Plot of f(x, y, z) = 1');
I hope you are doing well. I have plotted (in the attached file) the contour plot of the function and its density plot; both have the same behavior but different appearances (error in direction may be rotation needs to apply). I don't know why it happens because this code works well for other solutions. Kindly have a look and fix the issue. I shall be waiting for your positive response. Please take care.
Help.mw
I do not understandwhat this result from Maple means.
I don't know what it means when a result has "Root of", and in this case, there is also a big summation sign for which I can't tell if the variables underneath it are part of the summartion, or what.  I'd appreciate any guidance to make sense of what this means..
with(inttrans)
assump := R1::real, R2::real, L1::real, C1::real, C2::real, L2::real, omega::real, M::real, R1 > 0, R2 > 0, L1 > 0, C1 > 0, L2 > 0, C2 > 0, omega > 0, M > 0
R1::real, R2::real, L1::real, C1::real, C2::real, L2::real, omega::real, M::real, 0 < R1, 0 < R2, 0 < L1, 0 < C1, 0 < L2, 0 < C2, 0 < omega, 0 < M
expr := Vin/(s*(R1+s*L1-1/(s*C1)+(omega*M)^2/(R2+s*L2-1/(s*C2))))
Vin/(s*(R1+s*L1-1/(s*C1)+omega^2*M^2/(R2+s*L2-1/(s*C2))))
invlaplace(expr, s, t)
Vin*C1*(sum(exp(_alpha*t)*(-1+C2*_alpha*(L2*_alpha+R2))/(4*C1*C2*L1*L2*_alpha^3+2*C1*C2*M^2*_alpha*omega^2+3*C1*C2*L1*R2*_alpha^2+3*C1*C2*L2*R1*_alpha^2+2*C1*C2*R1*R2*_alpha-2*C1*L1*_alpha-2*C2*L2*_alpha-C1*R1-C2*R2), _alpha = RootOf(1+C1*C2*L1*L2*_Z^4+(C1*C2*L1*R2+C1*C2*L2*R1)*_Z^3+(C1*C2*M^2*omega^2+C1*C2*R1*R2-C1*L1-C2*L2)*_Z^2+(-C1*R1-C2*R2)*_Z)))
Download for_help2.mw
I noticed that the Linearly Implicit Euler method (also known as the Semi-Implicit Euler method) is not available in Maple's built-in ODE solvers. This method is useful for stiff ODEs, where part of the function is treated implicitly (for the linear term) and part is treated explicitly (for the non-linear term).
I know that the Linearly Implicit Euler method is a specialized method that probably does not find enough widespread use to justify its inclusion as a standard feature in Maple, especially given Maple's focus on numerical methods such as Runge-Kutta methods and fully implicit methods for rigid equations.
I’m wondering:
  1. Why isn’t this method included in Maple’s standard set of numerical solvers?
  2. How can I implement this method in my own code in Maple to solve stiff ODEs?
Any guidance or examples of implementation would be greatly appreciated!
Linearly_Implicit_Method.pdf
I need to order a set of polynomials based on a given ranking. For example:
F:=[F1,F2,F3,F4,F5,F6]:
F1 := x1*x4^2+x4^2-x1*x2*x4-x2*x4+x1*x2+3*x2;
F2 := x1*x4-x3-x1*x2;
F3 := x3*x4-2*x2^2-x1*x2-1;
F4 := x1*x3^2+x3^2-x1^2*x2*x3-x1*x2*x3+x1^3*x2+3*x1^2*x2;
F5 := -x3^2 + x1*x2*x3 -2*x1*x2^2-x1^2*x2-x1;
F6 := 2*x1*x2^2+2*x1^2*x2^2-2*x1^2*x2+x1^2+x1;
The order used to rank the polynomials is based on the variables in the following order: x1 < x2 < x3 < x4.
The ranking criteria are:
  1. The first polynomial should be the one involving x4 with the lowest degree of nonlinearity in x4 and the fewest number of terms (in this case, F2).
  2. The next polynomial should also involve x4, but with the lowest degree of nonlinearity and the next fewest number of terms and so on.
  3. Once the polynomials in x4 are exhausted, the ranking continues similarly for the next variable x3, followed by x2, and finally x1.
How can I do this efficiently?
Obs.:If necessary, I can share my solution to the problem, though it's far from efficient.
I am attempting to solve what appears to be a simple system of two ordinary differential equations (ODEs) (please find the attached file). However, I encountered an error message from Maple stating: "division by zero."
Could anyone suggest an approach to obtain a closed-form solution for this system?
Please note that the system includes two variables: S(t) and K(t). All other symbols represent positive parameters.
Thank you in advance for your assistance!
Best regards,
Dmitry
Download ODE.mw
I use the solve commant. The restult is a function with y as variable.
But when I want to use that function, the variable is not recognized.
How can this be fixed?
solve_no_variable_v1.mw
Good morning, please tell us how to graph on a map the graph that is seen in the image with those colors and their areas for the following exercise:
1. Draw the graph and find the area of ​​the region that is inside the cardioid r=2+2 cosθ and outside the circumference r=3
Calculate the area of ​​the region common to the two regions limited by the following curves:
r1= -6*cos(θ) Circle
r2= 2-2*cos(θ) Cardioid
A classic task from surveying that is unfortunately no longer taught in our GPS age and is worth remembering:
A hiker has lost his way and wants to know where he is. He has a map, a compass, paper, pen and calculator in his bag. From his position he sees three distant objects from left to right: a radio mast F, a chimney S and a church tower K. He also finds these objects on his map. Using his compass he aims at the three objects and measures the angles at which the distances FS and SK appear: angle for FS=alpha, angle for SK=beta. The hiker also manages to get the approximate coordinates of the three objects from the map to scale: F=(xf;yf), S=(xs;ys) and K=(xk;yk).
Question:
What are the hiker's coordinates?
Hello, I am having problem in solving the pde in the image using maple. Due to its nonlinear nature it has been solved for small value of v using first order perturbation technique and seperation of variable method into radial and angular part in many papers. I am having trouble in proceeding as Maple complains about Boundary/Initial condition.Please tell me if Maple can provide any help in improving existing solution or providing new solution? I can post the full solution procedure by the method i mentioned if needed.
ode0 := (diff(xi^2*(diff(theta[E](xi), xi)), xi))/xi^2 = -theta[E](xi)^n
(2*xi*(diff(theta[E](xi), xi))+xi^2*(diff(diff(theta[E](xi), xi), xi)))/xi^2 = -theta[E](xi)^n
bc0 := theta[E](0) = 1, (D(theta[E]))(0) = 0
base := dsolve({bc0, ode0}, theta[E](xi), series)
theta[E](xi) = series(1-(1/6)*xi^2+((1/120)*n)*xi^4+O(xi^6),xi,6)
pde1 := (diff(xi^2*(diff(psi(xi, mu), xi)), xi))/xi^2+(diff((-mu^2+1)*(diff(psi(xi, mu), mu)), mu))/xi^2 = -psi(xi, mu)^n+v
(2*xi*(diff(psi(xi, mu), xi))+xi^2*(diff(diff(psi(xi, mu), xi), xi)))/xi^2+(-2*mu*(diff(psi(xi, mu), mu))+(-mu^2+1)*(diff(diff(psi(xi, mu), mu), mu)))/xi^2 = -psi(xi, mu)^n+v
bc1 := psi(0, mu) = 1, (D[1](psi))(0, mu) = 0, (D[2](psi))(0, mu) = 0, limit(psi(xi, mu), v = 0) = rhs(base)
psi(0, mu) = 1, (D[1](psi))(0, mu) = 0, (D[2](psi))(0, mu) = 0, psi(xi, mu) = series(1-(1/6)*xi^2+((1/120)*n)*xi^4+O(xi^6),xi,6)
pdsolve(pde1, [bc1], psi(xi, mu))
Error, (in pdsolve/sys) too many arguments; some or all of the following are wrong: [[psi(xi,mu)], [psi(0,mu) = 1, D[1](psi)(0,mu) = 0, D[2](psi)(0,mu) = 0, psi(xi,mu) = series(1-1/6*xi^2+1/120*n*xi^4+O(xi^6),xi,6)]]
Download Nonlinear_Elliptic_PDE_in_Spherical_Coordinate.mw
First 67 68 69 70 71 72 73 Last Page 69 of 2429
