As I assumed 'n' and 'm' are real, eta is complex. But still, there is a bar on these discrete independent variables. Secondly, the substitution of (8) applies in some terms of 'r2', and the remaining terms remain as is it.
with(LinearAlgebra); with(PDEtools); with(plots); with(LREtools)
setup(mathematicalnotation = true)
assume(n::real); assume(m::real)
A := proc (n, m) options operator, arrow; Matrix([[eta*phi(n, m), conjugate(eta)*conjugate(psi(n, m))], [phi(n, m), conjugate(psi(n, m))]]) end proc; Adet := Determinant(A(n, m))
eta*phi(n, m)*conjugate(psi(n, m))-conjugate(eta)*conjugate(psi(n, m))*phi(n, m)
B := proc (n, m) options operator, arrow; Matrix([[phi(n, m), conjugate(psi(n, m))], [-psi(n, m), conjugate(phi(n, m))]]) end proc; Bdet := Determinant(B(n, m))
phi(n, m)*conjugate(phi(n, m))+conjugate(psi(n, m))*psi(n, m)
r := Adet/Bdet
(eta*phi(n, m)*conjugate(psi(n, m))-conjugate(eta)*conjugate(psi(n, m))*phi(n, m))/(phi(n, m)*conjugate(phi(n, m))+conjugate(psi(n, m))*psi(n, m))
p := {eta = 1+I, phi(n, m) = (1+I*a*eta)^n*(1+I*b*eta^2)^m, psi(n, m) = (1-I*a*eta)^n*(1-I*b*eta^2)^m, conjugate(eta) = 1-I, conjugate(phi(n, m)) = (1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m, conjugate(phi(n, m)) = (1+I*a*conjugate(eta))^n*(1+I*b*conjugate(eta)^2)^m}
r1 := simplify(subs(p, r))
(2*I)*(1+I*a*eta)^n*(1+I*b*eta^2)^m*conjugate((1-I*a*eta)^n*(1-I*b*eta^2)^m)/((1+I*a*eta)^n*(1+I*b*eta^2)^m*(1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n)*abs(I*b*eta^2-1)^(2*m))
r2 := 1-I*delta(r1, n)
1-I*((2*I)*(1+I*a*eta)^(n+1)*(1+I*b*eta^2)^m*conjugate((1-I*a*eta)^(n+1)*(1-I*b*eta^2)^m)/((1+I*a*eta)^(n+1)*(1+I*b*eta^2)^m*(1-I*a*conjugate(eta))^(n+1)*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n+2)*abs(I*b*eta^2-1)^(2*m))-(2*I)*(1+I*a*eta)^n*(1+I*b*eta^2)^m*conjugate((1-I*a*eta)^n*(1-I*b*eta^2)^m)/((1+I*a*eta)^n*(1+I*b*eta^2)^m*(1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n)*abs(I*b*eta^2-1)^(2*m)))
exp_expr := subs({(1+I*b*eta^2)^m = exp(I*eta^2*t)}, r2)
1-I*((2*I)*(1+I*a*eta)^(n+1)*exp(I*eta^2*t)*conjugate((1-I*a*eta)^(n+1)*(1-I*b*eta^2)^m)/((1+I*a*eta)^(n+1)*exp(I*eta^2*t)*(1-I*a*conjugate(eta))^(n+1)*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n+2)*abs(I*b*eta^2-1)^(2*m))-(2*I)*(1+I*a*eta)^n*exp(I*eta^2*t)*conjugate((1-I*a*eta)^n*(1-I*b*eta^2)^m)/((1+I*a*eta)^n*exp(I*eta^2*t)*(1-I*a*conjugate(eta))^n*(1-I*b*conjugate(eta)^2)^m+abs(-1+I*a*eta)^(2*n)*abs(I*b*eta^2-1)^(2*m)))
plot3d(abs(exp_expr), n = -5 .. 5, t = -5 .. 5, eta = 1+I)
Error, (in plot3d) unexpected option: eta = 1+I
Download soldis.mw
Maple dsolve allows one to specify the algorithm to use to solve the ode. But sometimes it is very tricky to figure the syntax,
This ode
ode:=diff(y(x),x)*y(x)+a*x*y(x)+b*x^3=0;
DEtools:-odeadvisor(ode);
Gives
               [[_homogeneous, `class G`], _rational, [_Abel, `2nd type`, `class A`]]
I wanted now to call dsolve telling dsolve to use the first method above. But how? All the following syntax failed for me
sol:=dsolve(ode,['_homogeneous, `class G`']);
sol:=dsolve(ode,'[_homogeneous, `class G`]');
All return method not found .
I am sure I am using wrong syntax but do not know what the correct one should be.
infolevel[dsolve]:=5;
sol:=dsolve(ode);
gives
Methods for first order ODEs:
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying homogeneous G
<- homogeneous successful
With long solution printed now OK.
When using just '[homogeneous]' it works
sol:=dsolve(ode,'[homogeneous]');
It gives same solution as default case.
What is the correct syntax to tell dsolve to use specific method [_homogeneous, `class G`] ? i.e. I need to add class G
The reason I ask is becuase Maple have different kind of homogeneous method as described here
Maple 2023.2.1 on windows 10
b := Matrix(3, 6, [[-1/2, 0, 1/2, 0, 0, 0], [0, 0, 0, -1/2, 0, 1/2], [0, -1/2, -1/2, 1/2, 1/2, 0]]);
i want  to show like this
How i can generate sequence of greek letters like this with latin letters
seq(convert(StringTools[Char](k),name),k=97..122);
I've encountered a problem with a piece of code involving an integral that should theoretically yield an exact solution. However, when running the code in Maple, I'm not getting the expected output
compute_integral.mw
Your assistance in resolving this matter would be greatly appreciated.
Thank you for your help.
It seems that applyrule cannot handle variable numbers of arguments, and I cannot use something like
applyrule(f(u::anything, v::seq(anything)) = g(v, u), [f(x, y, z), f(x, y, z, t)]);
Strangely, Maple does support the identical patterns in parameter declarations:
eval([f(x, y, z), f(x, y, z, t)], f = ((u::anything, v::seq(anything)) → g(v, u)));
                  [g(y, z, x), g(y, z, t, x)]
So the two designs do not appear coherent. Should this be regarded as a "bug" in a sense?
Of course there is no need to use the  modifier; here it is enough to use
evalindets([f(x,y,z),f(x,y,z,t)],'specfunc'(anything,f),w->g(op(2..(),w),op(1,w))):
use f = MakeFunction('g(args[2 .. ], args[1])') in [f(x, y, z), f(x, y, z, t)] end:
use f = unapply('g(_rest, _w)', [_w::anything]) in [f(x, y, z), f(x, y, z, t)] end:
But the problem is, why is there such inconsistency described above?
Given equation
We see this can be simplified to
In Mathematica, I just need to tell it the denominator of the left side is not zero for it to do the simplification
The same thing in Maple did not work:
eq:= (y-2*x)^3/( (y-x)^2 * x ) = a/x;
the_denom:= denom(lhs(eq));
simplify(eq) assuming the_denom <>0
No change.
I am doing this in code not by looking at the screen and simply wanted to eliminate common terms on both sides of equation. I can in code obtain the denominator of the LHS and RHS and add assumption. But since I do not know what if any common terms are on both sides, it is not easy to use elminate.
I see code at https://www.mapleprimes.com/questions/227043-How-To-Automatically-Cancel-Any-Common which actually worked on this and it did automatically elminate x from both sides.
But my question is: why Maple does not do it using simplify with the assumption given?  Tried simplify with size and no change.
I am looking for the simplist method to elminate common terms on both sides of equation. Is the link above the only way to do this in Maple? May be there is something simpler in recent Maple versions?
#code from https://www.mapleprimes.com/questions/227043-How-To-Automatically-Cancel-Any-Common
eq:= (y-2*x)^3/( (y-x)^2*x) = a/x;
TT := simplify(expand((eq)),size):
if lhs(TT)::`*` and rhs(TT)::`*` then
  TTT := map[2](map,freeze,TT);
  comm := `*`(op({op(lhs(TTT))} intersect {op(rhs(TTT))}));
  new := simplify(thaw(lhs(TTT)/comm=rhs(TTT)/comm));
end if:
new
May be this should be part of Maple build in functions and used by simplify?
Update
I just hit on a way to do this automatically with no assumption of anything. The idea is to simply rewrite the equation, like this
numer(lhs(eq))*denom(rhs(eq)) /  (denom(lhs(eq)) *numer(rhs(eq)))=1;
You see, the common term on both sides is automatically gone!   I need to test this more.
To moderator: if you think this question is duplicate, feel free to delete it.
Although I still prefer applyrule (as evalindets/subsindets is not as intuitive as applyrule),  I have heard that it is regarded as being more or less antiquated in modern Maple. I notice that a lot of (yet not all) examples given in the help pages of evalindets/subsindets can be reformulated by applyrule, but does any use of applyrule also correspond to using evalindets/subsindets? And if so, how to equivalently rewrite those transformation rules (especially complicated ones like nested function applications) in the syntax of evalindets/subsindets?
Dear Maple users/ experts
I have three functions, each with two parameters, alpha and delta, changing over 0..1. I want to partition the region in terms of what part gets the highest value. In the attached maple file, I used "implicit plot" and did it for any pair of functions in a reasonable time. But I don't know how these three plots can be consolidated into one. ('inequal' command was not precise while taking too long).  2D_implicitplot_with_three_functions.mw
Hi everyone and happy new year to all.
My question is: Is there a way to change the position of the axes labels in a plot? say, put them at the far end of the axes as some other softwares do. And is there any way to end the axes with arrows?
Axes labels position
kernelopts(version)
`Maple 2021.2, APPLE UNIVERSAL OSX, Feb 1 2022, Build ID 1590019`
y := proc (x) options operator, arrow; 1/abs(x) end proc
plot(y(x), x = -4 .. 4)
Download labels.mw
There are things that seem simple but rapidly turn into a nightmare.
Here is an example: what I want is to the expression given at equation (4) in the attached file.
Using Int gives a wrong result.
Using int gives a right one but not of the desired form (some double integrals are nested while others are not).
I've been stuck on this problem for hours, can you please help me to fix it?
TIA
use Statistics in
  # For more generality defina an abstract probability distribution.
  AbstractDistribution := proc(N)
    Distribution(
      PDF = (x -> varphi(seq(x[n], n=1..N)))
  # Define two random variables pf AbstractDistribution type.
  X__1 := RandomVariable(AbstractDistribution(2)):
  X__2 := RandomVariable(AbstractDistribution(2)):
end use;
proc (N) Statistics:-Distribution(Statistics:-PDF = (proc (x) options operator, arrow; varphi(seq(x[n], n = 1 .. N)) end proc)) end proc
_R
_R0
F := (U1, U2) -> U1/(U1+U2);
T := mtaylor(F(X__1, X__2), [X__1=1, X__2=1], 2):
proc (U1, U2) options operator, arrow; U1/(U1+U2) end proc
Error: x[2] is droped out of the double integral in the rightmost term
use IntegrationTools in
J := eval([op(expand(T))], [seq(X__||i=x[i], i=1..2)]);
L := add(
       map(
         j ->
         if j::numeric then
           j
           (Expand@CollapseNested)(
             Int(
               j * Statistics:-PDF(X__1, x)
               , seq(x[i]=-infinity..+infinity, i=1..2)
         end if
         , J
ET := %
end use;
[1/2, (1/4)*x[1], -(1/4)*x[2]]
1/2+(1/4)*(Int(x[1]*varphi(x[1], x[2]), [x[1] = -infinity .. infinity, x[2] = -infinity .. infinity]))-(1/4)*x[2]*(Int(varphi(x[1], x[2]), [x[1] = -infinity .. infinity, x[2] = -infinity .. infinity]))
I want this
'ET' = 1/2
       (1/4)*(Int(Int(x[1]*varphi(x[1], x[2]), x[1] = -infinity .. infinity), x[2] = -infinity .. infinity))
       -(1/4)*(Int(Int(x[2]*varphi(x[1], x[2]), x[1] = -infinity .. infinity), x[2] = -infinity .. infinity))
ET = 1/2+(1/4)*(Int(Int(x[1]*varphi(x[1], x[2]), x[1] = -infinity .. infinity), x[2] = -infinity .. infinity))-(1/4)*(Int(Int(x[2]*varphi(x[1], x[2]), x[1] = -infinity .. infinity), x[2] = -infinity .. infinity))
With int instead of Int one integral is double the other is double-nested
L := add(
       map(
         j ->
         if j::numeric then
           j
             int(
         end if
         , J
ET := %
1/2+int(int((1/4)*x[1]*varphi(x[1], x[2]), x[1] = -infinity .. infinity), x[2] = -infinity .. infinity)+int(-(1/4)*x[2]*(int(varphi(x[1], x[2]), x[1] = -infinity .. infinity)), x[2] = -infinity .. infinity)
As the expression of ET is now correct, I tried to use IntegrationTools to get the
form I want (equation (4)).
But as soon as I replace int by Int x[2] is again droped out.
So it's not even worth thinking about using CollapseNested!
  eval(ET, int=Int);
end use;
1/2+Int(Int((1/4)*x[1]*varphi(x[1], x[2]), x[1] = -infinity .. infinity), x[2] = -infinity .. infinity)+Int(-(1/4)*x[2]*(Int(varphi(x[1], x[2]), x[1] = -infinity .. infinity)), x[2] = -infinity .. infinity)
Download Int_int.mw
Given an expression expr, and symbol, say I wanted to check that only shows as argument to a specific Maple function. In this case, say ln() just an example but this can be any other function.
But if shows up in the expression but not as argument to ln() then I want to detect this also. So the function is passed the expression and the symbol name, and it returns true or false.
True means the symbol only shows inside ln and false means it found in the expression but not inside ln()
I can find all indets where the symbol shows inside the function. But the problem is how to find if the symbol shows outside of the function?
I think I need to use depends() somehow. But could not figure out how do far. Below is the code I have and few test examples and the result expected.
is_symbol_inside_func_only:=proc(expr::anything,f,y::symbol)::truefalse;
local the_type:=`Or`(
          'specfunc( `&*`(anything,identical(y)), f )',
          'specfunc( identical(y), f )'  ,
          'specfunc( `&+`(anything,identical(y)), f )'
local T;
T:=indets(expr, the_type );
print(T);
#need to check that y does not show any where inside expression unless
#as argument to f
RETURN(true); #or RETURN(false);
Here some test cases
expr:=3*ln(1+y)+ln(3*y)*y+ln(y)+cos(7*y);
is_symbol_inside_func_only(expr,ln,y); #should return false
expr:=3*ln(1+y)+ln(3*y);
is_symbol_inside_func_only(expr,ln,y); #should return true
expr:=ln(y)+ln(3*y)+cos(y);
expr:=3+cos(y);
is_symbol_inside_func_only(expr,cos,y); #should return true
expr:=y+ln(y);
expr:=-1/2*ln(y-1)+1/3*ln(y)+1/6*ln(y-3):
some context: I wanted to apply exponential to an expression to convert all ln(y)+ln(1+y)+...  to exp(...) to make it easy to process.
But wanted to do this ONLY if all terms that has are functions on ln otherwise, I will not raise it to exp in this case. The expression will always have the symbol in it. So need to worry about this case.
Update
After asking the question, I thought about using selectremove and it seems to do what I want. But need to test it more.
local hasF,nothasF;
hasF,nothasF:=selectremove(hastype,expr,the_type);
if has(nothasF,y) then
   RETURN(false);
   RETURN(true);
fi;
Here is the result
expr:=3*ln(1+y)+ln(3*y)*y+ln(y)+cos(7*y):
expr:=3*ln(1+y)+ln(3*y):
expr:=ln(y)+ln(3*y)+cos(y):
expr:=3+cos(y):
expr:=y+ln(y):
Update
I just found my function has a bug. I added one more test case. so you can ignore my function and use any of the other ones given in the answers below.
Maple 2023.2.1
The command "if x+x=2*x then print(1) else print(0) fi" gives the output 1. Similarly for
x*x=x^2. But "if (x+1)^2=x^2+2*x+1 then print(1) else print(0) fi" gives 0. I suppose that this isn't considered a bug, but could someone explain the rationale behind it? How does one get this type of command to behave in what I would consider the intuitive way?
Hi. i want to create a list of n random 0 and 1 numbers with x numbers equal to 1 and n-x number equal to zero.
for example in the code below, i have produced n=100 numbers of 0 and 1. But i want to create a proc that takes x as an input and generates this list with specified number of x numbers 1 and n-x numbers zero randomly. thanks for the help
restart:with(RandomTools):
n:=100
100
A:=[seq](Generate(choose({0, 1})),i=1..n)
[0, 0, 0, 1, 0, 1, 1, 1, 0, 1, 1, 1, 0, 0, 1, 0, 1, 0, 1, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 1, 0, 1, 1, 0, 0, 1, 1, 1, 1, 0, 0, 0, 1, 0, 1, 0, 1, 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 0, 0, 0, 0, 1, 1, 1, 0, 1, 1, 1, 0, 1, 0, 0, 0, 0, 1, 1, 0, 0, 1, 0, 1, 0, 1, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0]
Download problem.mw
The command
plot(x^(1/3), x = -10 .. 10)
plots only the points where x>=0, as for negative values of x the cubic root retuns only the complex root.
Ca can I modify it so that it returns only the real root, so that the whole plot can be viewed?
First 144 145 146 147 148 149 150 Last Page 146 of 2430
