Consider
alias(x=x(t),y=y(t),phi1=phi1(x(t),y(t)));
phi:=[x,ph1];
I need to calculate the Jacobian of phi in relation to x and y (and finally to t)  but using VectorCalculus[Jacobian] does not work. I guess it is because of the time dependence.   What am I missing?
Can the Physics package be used?
Many thanks.
I want to update Alphabets in my ‘for loop’ instead of numbers. Please look at the code below:
for Tl from 263 by 5 to 313 do
   for Ql from 25 by 25 to 300 do
        myvel:= my_porous(Ql, Tl, ratiol);
        Export(<myvel>, "HPporousmodel.xlsx", 1, my_alph[vcount]);
        vcount := vcount+1;
   end do
end do
Here, my_alph is a manually created alphabets corresponding to excel columns as below:
my_alph:=[ "A1", "B1", "C1", "D1", "E1", "F1", "G1", "H1", "I1", "J1", "K1", "L1", "M1", "N1", "O1", "P1", "Q1", "R1", "S1", "T1", "U1", "V1", "W1", "X1", "Y1", "Z1", "AA1", "AB1", "AC1", "AD1", "AE1", "AF1", "AG1", "AH1", "AI1", "AJ1", "AK1", "AL1", "AM1", "AN1", "AO1", "AP1", "AQ1", "AR1", "AS1", "AT1", "AU1", "AV1", "AW1", "AX1", "AY1", "AZ1", "BA1", "BB1", "BC1", "BD1", "BE1", "BF1", "BG1", "BH1", "BI1", "BJ1", "BK1", "BL1", "BM1", "BN1", "BO1", "BP1", "BQ1", "BR1", "BS1", "BT1", "BU1", "BV1", "BW1", "BX1", "BY1", "BZ1"]:
The idea is to export the velocity vector that I get from proc (my_porous(Ql, Tl, ratiol)) in to an excel sheet (HPporousmodel.xlsx)with the command (Export(<myvel>, "HPporousmodel.xlsx", 1, my_alph[vcount]);). I want to export the velocities into a new column for every iteration starting from A, B, C,….. and so on. However, since I don’t know how to do that I’ve used a manually created list my_alph. This has a big disadvantage of restricting the number of times I can loop. For this case, I can only loop (3*26=78 times). Anything more asks for manually increasing the entries of my my_alph list. I want to loop for 100's of times which is becoming a big problem with this method.
Can anyone please help me in automating this without any such constraints as we do with numbers (like we have done for vcount here)?
I am trying to export a 3D plot from Maple (2021) in a vector format that can be imported into Adobe Illustrator without too much trouble. The graphic artist says the PDF files are not useful (“at the base of every PDF is an image file, inside layers and layers of clipping paths; not helpful”). “SVG does not appear to produce usable vectors – well, maybe not, but the one you sent me was super difficult to wrangle”. She had hoped that EPS would be useful, but she was unable to open the EPS file I created (not enough memory).
Here is the example that I have been using as I've asked others for help with this question.
with(plottools);
T := torus([0, 0, 0], 1/2, 1/2);
C0 := spacecurve([cos(t), sin(t), 0], t = 0 .. 2*Pi, color = red, thickness = 9);
C1 := spacecurve([0.5*cos(t), 0.5*sin(t), 0.5], t = 0 .. 2*Pi, color = red, thickness = 9);
C2 := spacecurve([0.5*(1 + cos(t)), 0, 0.5*sin(t)], t = 0 .. Pi, color = blue, thickness = 9);
C3 := spacecurve([0.5*(-1 + cos(t)), 0, 0.5*sin(t)], t = 0 .. Pi, color = blue, thickness = 9);
Fig9510 := display([T, C0, C1, C2], view = [DEFAULT, DEFAULT, 0 .. 1/2], scaling = constrained, transparency = 0.75);
Direct links to the worksheet and the PDF, EPS, and SVG files on DropBox are provide below in the hope that something will be useful to somebody. (MaplePrimes links are provided for the MW and PDF files are also provided - but EPS and SVG files are not permitted.)
  1. 3DPlotExample.mw: https://www.dropbox.com/s/mx1hg1ntuqihnu3/3DPlotExample.mw?dl=0
  2. Fig9510.pdf: https://www.dropbox.com/s/bnzfqrh060gw84g/Fig9510.pdf?dl=0
  3. Fig9510.eps: https://www.dropbox.com/s/h9bjyn0uwm8w5ct/Fig9510.eps?dl=0
  4. Fig9510.svg: https://www.dropbox.com/s/u2xfntnqvbhu810/Fig9510.svg?dl=0
This question has been asked for more than ten years. The best solution to has been to use the command-line-interface version of Maple.
  1. Is the command-line interface still the best/only option for vector-based graphics output?
  2. If so, how do i access the command-line version of Maple 2021 on MacOS?
Hello, I have a program which works fine in maple but get stuck when I use it in maple 2021 please I need your help thank you in advance
mpprime.mw
This is my first time working on a problem using Maple, and I've run into some issues regarding plotting my findings. After putting in the information for the plot (p:= plot([y1], t = 0..56562.16837, y = 0.10]), I keep receiving the warning "Expecting only range variable t in expression y[1] to be plotted but found name y[1]. I attached the Maple worksheet below for more information, trying to work my way through plotting in Maple.
Worksheet.mw
I would like the display of a piecewise-function F with DocumentTools:-Tabulate to look like the one I get with print.
How is it possible to do this?
Here is an example
with(DocumentTools):
with(DocumentTools:-Layout):
MV := kernelopts(version);
Maple 2015.2, APPLE UNIVERSAL OSX, Dec 20 2015, Build ID 1097895
# Extract the version number for subsequent use
MV := parse(substring(StringTools:-Split(convert(MV, string), ",")[1], 7..-1))
# I want to display F and G while using DocumentTools
# As you see the display of F is not very pretty.
# This is not a problem related to the "height" of the formula for G is pretty-displayed
# even if it as roughly the same "height" than F
F := piecewise(seq(op([x<k, k]), k=1..5)):
g := x -> 1/(1+x):
G := (g@@5)(x):
Tabulate([F, G]):
# using DocumentTools:-Layout doesn't help
C1 := Cell( Textfield(style=TwoDimOutput,Equation(F))):
C2 := Cell( Textfield(style=TwoDimOutput,Equation(G))):
T  := Table(Column(),Column(),
         Row( C1, C2 )
if MV < 2018 then
  InsertContent(Worksheet(Group(Input( T )))):
  InsertContent(Worksheet( T )):
This is what DocumentTools:-Tabulate displays
DocumentTools_piecewise.mw
TIA
The attached worksheet is a stripped down version of some notes I am creating concerning the solution of vector equations in geometric algebra.  For the purposes of explanation it is best to show the math in its conventional typeset form before showing how to solve the equations in maple. The non-excutable math is in the text which is contained in a paragraph inserted before the execution group. In the first instance, the typesetting engine seems content to leave the text alone, but in the second case (which I created in the same way) it insists on parsing the equations and generating errors. I have tried repeatedly to make the second set of equations non-executable (since in maple terms they are nonsense) to no avail.
Can anyone suggest how I can use maple's text features to make the explanatory text inert.
Note that I have included the calls to my geometric algebra module in case they have some relevance to the problem, but they will not execute without the module.
Sample worksheet:  nonexecmatherror.mw
After using Maple for about a year now, I have quite a few worksheets and documents that I have created.  Often I would like to use code that I know I wrote in a previous document but I don't remember which file that was in.  It appears that those files are in a binary format.
Is there a Maple search utility or another way that would allow me to search a group of Mapele files for text?
David
Let expr defined this way
expr := piecewise(x(t)<0, -1, x(t)<1, 0, 1) + f(t) + piecewise(t<0, 0, t<1, 1, 0) + x(t)*piecewise(t<0, 1, t<1, 0, 1) + a*piecewise(t<0, 3, t<1, -1, 2)
How can I extract all the operators which contain a piecewise function of  t alone (the three bold operators in the expression above)?
TIA
I'm looking for a simple example on how to use the Edit Code Dragged (event), in a plot (embedded component).
I couldn't find it in the Maple Documentation of elsewhere.
Jos
Wrote some Maple code, and want to share.
I put less than eight hours into this exploration.
I have been running a computer to find Fermat factors for over ten years now.  Want support.
This is an exploration in some mostly composite whole numbers.
see 2_to_the_exponent_p_3.pdf
also see
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/2_to_the_exponent_p_3.mw .
Download 2_to_the_exponent_p_3.mw
Have a look.
Matt
ff := dsolve({eq1, Vt(0)=0}, Vt(t), type=numeric, method=classical, start=0, stepsize=.00001);
this is a old syntax of maple 5, with maple 2017 version it is not working, is it possible to solve non linear equatins with maple
When I click on the "install" option for the update to the Physics Package, get the following error message:
Fetching package "Physics Updates" from MapleCloud...
Version: 988
URL: https://maple.cloud
An error occurred, the package was not installed:
Unable to log into Maplesoft account: Forbidden (403)
The 3-D Workspace of the stuart platfrom example
https://de.maplesoft.com/products/maplesim/modelgallery/detail.aspx?id=34
displays as follows. Clicking on the central object I get
Q1: What does "Unlayed out view mean"?
Q2: What is actually displayed in the center?
Q3: Why is only one leg shown in instead of 6?
I would really appreciate more insight into the 3-D Workspace. I use it to inspect structural integrity of models and assembly errors, but I am often lost by its behavior.
(I have tried to work it out myself with online resources, Maples help system and MapleSim user guide.)
First 431 432 433 434 435 436 437 Last Page 433 of 2458
