I use the RamdonGraph function quite a bit and wanted to know if it is possible to generate random graphs with specific properties, beyond the typical order, size, connectednes, etc. Specifically, I am interesting in generating eulerian (containing an eulerian circuit), semi-eulerian (containing an eulerian trail) and hamiltonian (containing a spanning cycle)  graphs. Also, the abiltiy to randomly generate graphs that have none of these properties would be helpful.
How do I find the contents of a bin in a Maple histogram?
hello,
I computed some algebraic calculation, but near point -1 there is some issue like disconvergencies. Can anyone help in this regard? In the final graph, as seen the paths of the curves are close together and convergence does not occur AROUND POINT -1.
Digite := 30
30
beta := 2.5; lambda := 0.1e-1; b := Pi; a := Pi; alpha := 0; y[1] := 1.5; y[2] := 1.5; x[1] := -1; x[2] := 1; Q[1] := 40; Q[2] := 35; T[1] := 20
2.5
0.1e-1
Pi
Pi
1.5
-1
35
v := (2*n-1)*Pi/(2*b)
Delta := exp(2*v*a)*(alpha*v+beta)*(1+lambda)-(1-lambda)*(alpha*v-beta)
omega := Pi/(2*b)
P[1] := ((1+lambda)*exp(-v*abs(x-xi))+(1-lambda)*exp(v*(x+xi)))*exp(2*v*a)+(1+lambda)*exp(-v*(x+xi))+(1-lambda)*exp(v*abs(x-xi))
P[2] := ((1+lambda)*exp(-v*abs(x-xi))+(1-lambda)*exp(v*(x+xi)))*exp(2*v*a)-(1+lambda)*exp(-v*(x+xi))-(1-lambda)*exp(v*abs(x-xi))
P[3] := P[1]*(-alpha^2*v-alpha*beta+alpha*v)+beta*P[2]
G[11] := (sum((alpha*P[1]*(1-lambda)*(alpha*v-beta)*exp(-2*v*a)+(1+lambda)*P[3])*(cos(v*(y-eta))-cos(v*(y+eta)))/(v*(exp(2*v*a)*(alpha*v+beta)*(1+lambda)-(1-lambda)*(alpha*v-beta))), n = 1 .. 80))/(2*b*(1+lambda))+(2*(1+lambda)*alpha*b/Pi*.25)*ln((1+2*exp(-omega*abs(x-xi))*cos(omega*(y-eta))+exp(-2*omega*abs(x-xi)))*(1-2*exp(-omega*abs(x-xi))*cos(omega*(y+eta))+exp(-2*omega*abs(x-xi)))*(1+2*exp(-omega*(2*a+x+xi))*cos(omega*(y-eta))+exp(-2*omega*(2*a+x+xi)))*(1-2*exp(-omega*(2*a+x+xi))*cos(omega*(y+eta))+exp(-2*omega*(2*a+x+xi)))/((1-2*exp(-omega*abs(x-xi))*cos(omega*(y-eta))+exp(-2*omega*abs(x-xi)))*(1+2*exp(-omega*abs(x-xi))*cos(omega*(y+eta))+exp(-2*omega*abs(x-xi)))*(1-2*exp(-omega*(2*a+x+xi))*cos(omega*(y-eta))+exp(-2*omega*(2*a+x+xi)))*(1+2*exp(-omega*(2*a+x+xi))*cos(omega*(y+eta))+exp(-2*omega*(2*a+x+xi)))))/(2*b*(1+lambda))+(2*(1-lambda)*alpha*b/Pi*.25)*ln((1+2*exp(omega*(x+xi))*cos(omega*(y-eta))+exp(2*omega*(x+xi)))*(1-2*exp(omega*(x+xi))*cos(omega*(y+eta))+exp(2*omega*(x+xi)))*(1+2*exp(-omega*(2*a-abs(x-xi)))*cos(omega*(y-eta))+exp(-2*omega*(2*a-abs(x-xi))))*(1-2*exp(-omega*(2*a-abs(x-xi)))*cos(omega*(y+eta))+exp(-2*omega*(2*a-abs(x-xi))))/((1-2*exp(omega*(x+xi))*cos(omega*(y-eta))+exp(2*omega*(x+xi)))*(1+2*exp(omega*(x+xi))*cos(omega*(y+eta))+exp(2*omega*(x+xi)))*(1-2*exp(-omega*(2*a-abs(x-xi)))*cos(omega*(y-eta))+exp(-2*omega*(2*a-abs(x-xi))))*(1+2*exp(-omega*(2*a-abs(x-xi)))*cos(omega*(y+eta))+exp(-2*omega*(2*a-abs(x-xi))))))/(2*b*(1+lambda))
g[12] := lambda*((alpha*v+beta)*exp(v*(2*a+x))+(alpha*v-beta)*exp(-v*x))*exp(-v*xi)/(v*Delta)
G[12] := (sum(g[12]*(cos(v*(y-eta))-cos(v*(y+eta))), n = 1 .. 80))/b
phi[1] := int(int(G[11]*Q[1]*Dirac(xi-x[1])*Dirac(eta-y[1]), xi = -a .. 0), eta = 0 .. b)+int(int(G[12]*Q[2]*Dirac(xi-x[2])*Dirac(eta-y[2]), xi = 0 .. infinity), eta = 0 .. b)
Z[1] := diff(phi[1], x)
psi[1] := int(Z[1], y)
plot3d(psi[1], x = -a .. 0, y = 0 .. b)
with(plots)
contourplot(psi[1], x = -a .. 0, y = 0 .. b)
Download sai_1.mw
I have a guess about the set of the zeros of the following polynomial
y(1-x^{m+1}z)+(1-x^{n+1}z), (here m,n are positive integers and z is a primitive d-root of unity)
which are located on the complex 2-dimensional torus. The set of solutions is finite (I think the system is zero-dimensional). My goal is to verify my guess numerically using Maple for some small values of m and n and a fixed value of z. I think if (x,y) is a solution, then x is either a (n-m) root of unity or a (n-m) root of 1/z^2 (where n>m).
You can find my code for n=3 and m = 1 attached (I was not able to load the mw format so I put the zip version). I consider z to be a third root of unity but actually, I am interested in putting z= exp(2pi/3*i) and even the real third root z=1 is not interesting for me, but since the exponential representation led to an error, I changed it to z and mentioned that z^3=1. Still, it has an error and  I would be grateful if you could let me know how I can correct this code.
Question.maple.zip
what the meaning this warning : Warning, cannot evaluate the solution further right of 1.3344882, probably a singularity
how to analize this warning
How do I format the display of numbers in Microsoft Excel 365 using the Maple 2023 Add-In?
The default formatting is inconsistent: displays as but displays as . At minimum, I would like all of the numbers to display using a consistent format, preferably standard scientific notation (1.27420168E7 and not or ).
I wanted to do a 3d plot such that a function is plotted over a polar plane. I am not sure what is the best way to plot this and would appreciate some guidance/tips.
I want to plot the following function 1/(r^2*sin(theta)^2) .
I tried plot3d but the base plane is not a circle but a square...
I have a i9 9th Generation processor with 32 GB ram
If I upgrade to a i9 13 Generation processor with 64 GB ram
Assume I change the main card to Z790
I wonder if I will notice a big improvement in performance when running Maple 2023?
Kjell
I have been writing a language translator. I have everything working reasonably well except that when translating abs(expr) with optimize=tryhard, the IntermediateCode converts the abs() into if...then...else statements. This would be fine except the type of the expr is generally a complex number. I need to optimize the code because there is a lot of redundant calculations otherwise.
I can't figure out how to get IntermediateCode from breaking the abs function into if...then...else statements. [My solution so far is to substitute abs with a dummy name and then use the translator to translate the dummy name into an abs statement - That's really not how things should work!]
Any suggestions?
I've included some example test cases of what is going wrong.
with(CodeGeneration)
testproc1 := proc (x) abs(x) end proc
IntermediateCode(testproc1, optimize = tryhard)
Scope( nametab,
  AssignedName(Name("testproc1"), Scope( nametab,
    Procedure(
      ParameterSequence(Declaration(Name("x"), Type(integer))),
      LocalSequence(Declaration(Name("s1"), Type(integer))),
      OptionSequence(),
      ExpressionSequence(),
      StatementSequence(
        If(
          ConditionalPair(LessEqual(Integer(0), Name("x")), StatementSequence(
            Assignment(Name("s1"), Name("x"))
          ConditionalPair(Less(Name("x"), Integer(0)), StatementSequence(
            Assignment(Name("s1"), Negation(Name("x")))
          StatementSequence(
            Assignment(Name("s1"), Integer(0))
        Return(Name("s1"))
      DescriptionSequence(),
      GlobalSequence(),
      LexicalSequence(),
      Type(integer)
testproc2 := proc (x::numeric) abs(x) end proc
IntermediateCode(testproc2, optimize = tryhard)
Scope( nametab,
  AssignedName(Name("testproc2"), Scope( nametab,
    Procedure(
      ParameterSequence(Declaration(Name("x"), Type(numeric))),
      LocalSequence(Declaration(Name("s1"), Type(numeric))),
      OptionSequence(),
      StatementSequence(
        If(
          ConditionalPair(LessEqual(Float(0, 0), Name("x")), StatementSequence(
          ConditionalPair(Less(Name("x"), Float(0, 0)), StatementSequence(
          StatementSequence(
            Assignment(Name("s1"), Float(0, 0))
        Return(Name("s1"))
      GlobalSequence(),
      LexicalSequence(),
      Type(numeric)
testproc3 := proc (x::complex) abs(x) end proc
IntermediateCode(testproc3, optimize = tryhard)
Scope( nametab,
  AssignedName(Name("testproc3"), Scope( nametab,
    Procedure(
      ParameterSequence(Declaration(Name("x"), Type(complex))),
      LocalSequence(),
      OptionSequence(),
      StatementSequence(
        Return(FunctionCall(Name("abs"), ExpressionSequence(Name("x")), unknown))
      GlobalSequence(),
      LexicalSequence(),
      Type(numeric)
Download intermediate_code_abs.mw
I'm using NLPSolve to minimize a complicated function. It works great, but the answers are not returned in numerical form which I need as they are then input for the next stage of my program.
How to I extract numbers?
S2 := NLPSolve(test, phi1 = 0 .. 2*Pi, phi2 = 1.0*Pi .. 2*Pi);
     S2 := [-1.00000000011810774,
       [phi1 = 0.773215730257661, phi2 = 5.98741001513872]]
==>The Result is a list and the solutions appear kind of string-like.
S2[2,1] returns 'phi=0.773...' not the number I need
I have a system of  second order difference equation.
How, can I update the iterate solution and solve the system
System_of_equations.mw
I would like to verify if the proposed solution u_exact of my partial differential equation defined on \mathbb{R}^2, with zero boundary condition
I write the  exact solution, how substitute this  to verify that the PDE is satisfied or not. I tried to substitute but I think someting missing.
Please check ...
solution_pde_check.mwsolution_pde_check.mw
  ra:=2: b1:=1.41: na:=0.7: we:=0.5: eta[1]:=4*0.1: d:=0.5:
  xi:=0.1: m:=na: ea:=0.5: pr:=21: gr:=0.1: R:=0.9323556933:
  PDE1:=ra*(diff(f(x,t),t))=+b1*(1+ea*cos(t))+(1/(R^2))*((diff(f(x,t),x,x))+(1/x)*diff(f(x,t),x));
  IBC:= {D[1](f)(0,t)=0,f(1,t)=0,f(x,0)=0};
2*(diff(f(x, t), t)) = 1.41+.705*cos(t)+1.150367877*(diff(diff(f(x, t), x), x))+1.150367877*(diff(f(x, t), x))/x
{f(1, t) = 0, f(x, 0) = 0, (D[1](f))(0, t) = 0}
sol := pdsolve({PDE1}, IBC, numeric); sol:-plot(f(x, t), t = 1.2, linestyle = "solid", title = "Velocity Profile", labels = ["r", "f"])
Download pde.mw
for different time plot of f(x,t) in single plot with different color
acer helped me out last week with converting strings to dates which was very helpful. However now I stumble on 2 other problems:
- I do not succeed to plot DS6 (time difference versus a numeric value) and to not understand why
- in the cvs data sheet the length of the columns is not equal. The empty cells are automatical filled with "". This prevents me to use numelems as it will also take into consideration the cells filled with "". Is there a way to prevent this
As usual I would like to thank you all, power users, for your patience and help
Test.mw
Hi all
Let us consider the set [f1=x-y, f2=-x^2+y^2, f3=x*y+x*z, f4=-x*y*z+z^3, f5=x*y^2+y*z^2-z^3] contain homogeneous polynomials in K[x,y,z]. It has the elements of degree 1,2, and 3. Now, we start from degree 1 so we have [x-y]. Now, we go to degree 2. Now, we shall multiply f1 by the variables and add to this set f2 and f3 i.e. we have now
[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z]
 We have to continue to degree 3 and multiply f1 by all monomials in degree two in k[x,y,z] and multiply f2 and f3 by any variable and add them to f4 and f5 so we have finalyas a output:
[[x-y], [x^2-x*y, x*y-y^2, x*z-y*z, -x^2+y^2, x*y+x*z], [x^3-x^2*y, x^2*y-x*y^2, x^2*z-x*y*z, x*y^2-y^3, x*y*z-y^2*z, x*z^2-y*z^2, -x^3+x*y^2, -x^2*y+y^3, -x^2*z+y^2*z, x^2*y+x^2*z, x*y^2+x*y*z, x*y*z+x*z^2, -x*y*z+z^3, x*y^2+y*z^2-z^3]]. How can I do this automatically by a simple and efficient method in Maple?
First 212 213 214 215 216 217 218 Last Page 214 of 2469
